February 19, 2023, 23:56 |
Tuned Mass Damper in solids4Foam
Ben
Rep Power: 3 |
Hello. I've had success in modelling a building under wind loading using solids4Foam to solve for the fluid structure interaction, and I was wondering if there is any precedent as to how to model a tuned mass damper within the building. Ideally, I'd have a point mass connected by linear springs to the building that take into account its motion. I've seen that in https://openfoamwiki.net/index.php/P...onSolverFvMesh, it is possible to define a linear spring for a 6dof rigid body element, but I'm unsure if this would work, as the definition of the "anchor" parameter is "The anchor defines the fixed end point. This will remain fixed in position throughout your simulation." I'd need someway for the anchor to move with the motion of the building. If you know if there is some way to do this, or if there is a different method to model a tuned mass damper, please let me know. Thanks.
solids4foam |
mass fraction of species | Lilly | FLUENT | 5 | March 13, 2022 17:52 |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 19:24 |
Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 10:20 |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
