February 14, 2023, 10:24 |
Fluid zone mesh update
Yateng Qiao
Rep Power: 3 |
Dear Foamers,
I am working on a cylinder rotating in a fluid zone.(no interaction between fluid and solid. only fluid part, just a rigid body) I use the fluent3DMeshToFoam to generate the fluid mesh. The cylinder I give a wall boundary condition. My question is if the cylinder boundary is rotating with a constant angular velocity, how to define the dynamicMeshDict to allow the whole fluid domain mesh rotating with the cylinder wall. I mean I used dynamicMotionSolverFvMesh now, which dynamic mesh solver should I used to update the whole domain mesh at each time step? (the fluid field does not change, just the fluid mesh rotate with cylinder) Wish for your help Thanks so much! |
dynamicmeshdict, mesh update, solids4foam |
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent | Ayo_gboyega | ANSYS Meshing & Geometry | 1 | June 17, 2018 03:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
