[solids4Foam] rotation tube floating point exception |
Yateng Qiao
Rep Power: 3 ![]() |
Dear forumers,
I'm simulating a 3D cylinder rotating in a cylinder zone filled with fluid. I just use fluid tut without solid model. So my problem is just a fluid zone with a wall of cylinder. The boundary condition is as follows: p tube wall:zeroGradient Top.bottom.boundary: fixedValue uniform 0 u tube wall:newMovingWallVelocity Top:fixedValue uniform 0 bottom.boundary: zeroGradient When I run the case in parallel(decompose 40 parts in z deriction), after 0.24s(0.001s time step) there are some errors, I list in the png file. I'm not if the problem is from the mesh or the boundary condition. |
Yateng Qiao
fine, maybe the parallel running is the reason
Yateng Qiao
When I try to simulate the rotation of the cylinder based on fluid tutorial,the grid seems to stick to a wall. I'm not sure if the dynamicMesh method is wrong.
I list the x-y cut plane of the mesh deformation and the dynamicMeshDict as follows. |
dynamic mesh, rotation cylinder, solids4foam |
[blockMesh] Floating Point Exception while generating wedge based mesh | jns-v | OpenFOAM Meshing & Mesh Conversion | 9 | July 8, 2021 05:36 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
