Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Installing solids4foam v2.0 with FE4.1 on Ubuntu 20.04
Old   January 27, 2023, 11:56
Default Installing solids4foam v2.0 with FE4.1 on Ubuntu 20.04
Nicolas FORESTAL
Nicolas FORESTAL is on a distinguished road
hello,
I have some issues to compile solids4Foam on my laptop. I use Ubuntu 20.04 and I compile FOAM-Extend with gfortran 7. The Allwmake says the compilation is complete but I don't have the solver solids4Foam.
I attached a log file to the comment.
I'm new in CFD and programming and I didn't no why it doesn't work.
Is there anyone who can give me some advice for my case.
Thanks,
Nicolas FORESTAL is offline   Reply With Quote
Old   February 1, 2023, 17:06
Ivan Batistić
iBatistic is on a distinguished road
The compilation of the solver did not finish without error, read carefully log file, and you will find the problem in this line:
/usr/bin/ld*: ne peut trouver -lgfortran
collect2: error: ld returned 1 exit status
As a workaround, check the status of S4F_USE_GFORTRAN variable and set it to zero, then try compilation again.
iBatistic is offline   Reply With Quote
Old   February 2, 2023, 12:49
Nicolas FORESTAL
Thanks for your help. I set S4F_USE_GFORTRAN to zero but it didn't work. So I checked my gfortran compiler and installed gfortran-7, and now it's seem to work.
[OpenFOAM.com] Installing OpenFoam-v1706 on Ubuntu 20.04 Shahin123 OpenFOAM Installation 4 April 15, 2024 04:46
[OpenFOAM.com] Installing OpenFOAM 2.4.0 on Ubuntu 20.04 for Windows RKyle OpenFOAM Installation 5 January 25, 2022 11:45
[foam-extend.org] Installing FOAM-Extend 4.0 on Ubuntu 20.04 serfriz OpenFOAM Installation 19 November 8, 2021 19:24
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
OpenFOAM extended 4.0 Error with Multinode Set-up Liweix OpenFOAM Running, Solving & CFD 1 February 18, 2020 01:50
