Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Time-dependent solid case with hyper elastic model
Old   August 29, 2022, 03:27
Default Time-dependent solid case with hyper elastic model
PassengerC07 is on a distinguished road
Hi everyone,
Recently I started to work on an FSI project on aneurysm using pimpleFoam + solids4foam with the preCICE coupling interface. I struggled a bit with the solid mesh and model setup. Basically I want to test the solid case with solids4foam only first before doing any coupling. I simply copied the files from one of the hyperelastic tutorial cases and modified certain parts.
My question is, is it possible to run a time-dependent solid case with one of the current hyperelastic models (preferably mooney-rivlin)?
All the hyperelastic tutorial cases use steady state fvSchemes and my efforts to try hyperelastic model with time-dependent configuration have been fruitless (solver crashing either during setup for GAMG and some time into simulation for PCG).
Also, is there any on-going development for a 5-parameter Mooney-Rivlin model? If not, is it difficult to implement one myself? I had some luck with implementing a BC in OpenFOAM.
Thanks,
PassengerC07 is offline   Reply With Quote
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
