Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] does any method to consider added mass
Old   February 8, 2022, 09:50
Default does any method to consider added mass
Hojatollah Gholami
Hgholami is on a distinguished road
Hi
In fluid solid interaction solvers partitioned method (such as fsiFoam, solids4Foam), for interaction uses relaxation factor, because the transferred forces to solid region lead to displacement of solid with neglecting fluid region. So the displacement transfers to fluid region with fsi relaxation factor, that displaces fluid interface in a small amount, again in loop of fluid-solid solvers, the force calculated and transfer to solid and calculate displacement, then difference of new displacement and previous displacement multiply with fsi relaxation factor and plus to previous displacement. if previous displacement was high, the new force reduce it and if previous displacement was low, it increases.
This method have potential error that should test different relaxation factors, number of loop, etc.
does any other methods for replacing?
Hgholami is offline   Reply With Quote
fsi, relaxation factor
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Unfinished particle tracks in simpleReactingParcelFoam Cornelia OpenFOAM Running, Solving & CFD 3 June 5, 2015 04:58
