Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
FSI toolkit 4.1 help me!!
Old   January 20, 2022, 11:17
Default FSI toolkit 4.1 help me!!
Neb
Neb is on a distinguished road
Hi all, I am compiling FSI extend-bazaar from foam-extend 4.1 on Ubuntu 18.04 VM, but I get the following errors. Can someone help me? I'm desperate.
Thank you for your time
In file included from /home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.H:184:0,
from solidSolvers/solidModels/fvPatchFields/solidContact/contactModels/frictionContactModels/frictionLaws/timeVaryingCoulomb/timeVaryingCoulomb.H:45,
from solidSolvers/solidModels/fvPatchFields/solidContact/contactModels/frictionContactModels/frictionLaws/timeVaryingCoulomb/timeVaryingCoulomb.C:26:
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C: In member function ‘Type Foam::interpolationTable<Type>::rateOfChange(Foam: :scalar) const’:
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:276:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:310:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C: In member function ‘const Foam::Tuple2<double, Type>& Foam::interpolationTable<Type>:perator[](Foam::label) const’:
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:420:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:455:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C: In member function ‘Type Foam::interpolationTable<Type>:perator()(Foam::s calar) const’:
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:509:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
/home/simona/foam/foam-extend-4.1/src/foam/lnInclude/interpolationTable.C:543:17: error: attributes at the beginning of statement are ignored [-Werror=attributes]
[[fallthrough]];
cc1plus: all warnings being treated as errors
solidSolvers/solidModels/fvPatchFields/solidContact/contactModels/frictionContactModels/frictionLaws/timeVaryingCoulomb/timeVaryingCoulomb.dep:544: recipe for target 'Make/linux64GccDPInt32Opt/timeVaryingCoulomb.o' failed
make: *** [Make/linux64GccDPInt32Opt/timeVaryingCoulomb.o] Error 1
Neb is offline   Reply With Quote
Old   March 15, 2022, 15:02
Patrick Höhn
hoehnp is on a distinguished road
Hi Neb, the FSI toolkit from extend-bazaar is no longer actively maintained. It would be better to have a look at solids4Foam which is its successor.
hoehnp is offline   Reply With Quote
Old   September 22, 2023, 00:44
XinZhou
XinXin is on a distinguished road
Have you solved this problem?
XinXin is offline   Reply With Quote
[FSI] Foam-Extend 4.1 Extend Bazaar Allwmake fail compiling on Opensuse Tumblweed EternalSeekerX OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 May 18, 2020 22:47
[FSI] Installing FSI toolkit in foam-extend 4.0 treem22 OpenFOAM CC Toolkits for Fluid-Structure Interaction 5 August 8, 2019 07:06
OpenFoam 4.1 and FSI efirvida OpenFOAM Running, Solving & CFD 2 November 22, 2016 19:57
OpenFOAM 4.1 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 0 October 13, 2016 07:42
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
