[solids4Foam] Fixed-Rotation boundary doesn't affect whole mesh |
October 11, 2021, 13:20 |
Hi everyone,
In the attached case a fixed rotation boundary is added on the patch at the left end in the figure. All other patches are set to zeroGradient. As shown in the picture below, only a small part of the mesh is actually moving. However, I would rather expect that the whole pipe is uniformly rotating. A uniform could be only achieved if the mantle areas of the pipe are defined with fixed Rotation. However, this would be possible in the final model. I attached the underlying case to this issue. I am grateful for any suggestions. |
October 13, 2021, 06:50 |
Philip Cardiff
Rep Power: 34 |
Hi Patrick,
I suggest changing the following:
I tried this and the results seem reasonable. Philip |
April 13, 2022, 11:50 |
Vi Kumar
Rep Power: 9 |
Hey! Could you share your case file now, if it's working? I've been trying to simulate a rotating pipe with vibrations but I'm not having too much luck.
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
Fluid Domain moving with Rigid body | Lloyd Sullivan | CFX | 3 | August 17, 2018 10:58 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
