Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Simulation case of pipe rotating & oscillating using solids4Foam
Old   September 30, 2021, 14:59
Default Simulation case of pipe rotating & oscillating using solids4Foam
Mohamed Shanan
shanan12 is on a distinguished road
Good day everyone,
I am trying to run a simulation using solids4Foam, the final objective is to simulate a pipe that is rotating (around Z axis) and vibrating (oscillating in the Y axis direction) in the same time.
The blockMesh is composed of the patches inlet, outlet, inner-wall, and outer-wall
First I got the simulation to have a simple rotation without vibration by using the boundary condition of:
- inlet & outlet: zeroGradient
- inner-wall & outer-wall: fixedRotation
Second I got the case to vibrate without a rotation by using the boundary condition of:
- inlet: solidTraction
- outlet: fixedDisplacement
- inner-wall & outer-wall: zeroGradient
Both cases have the following:
- mechanical Model as neoHookeanElastic
- fvSchemes set as Euler in both d2dt2Schemes & ddtSchemes
- solidModel as nonLinearGeometryTotalLagrangianTotalDisplacement
when I tried to combine the two movement... rotational and oscillation, the model only rotate and does not oscillating an the is no effect for the solidTraction on the inlet what so ever.
using the following boundary condition of:
- inner wall Outer wall: fixedRotation
So I tried to change the boundary to the following:
- outlet: fixedRotation
- inner wall Outer wall: zeroGradient
However the problem here was that the outlet is rotating, causing deformation for the pipe and the rotation do not move along the pipe mesh, and still there is no effect of the solidTraction
Does anyone have idea is it possible to achieve two movement in the solid mesh simultaneously (Rotational movement & linear deformation along an axis) ?
shanan12 is offline   Reply With Quote
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Continuity error cannot be removed by adjusting the outflow - rotating domain case Swift OpenFOAM Running, Solving & CFD 4 July 10, 2017 09:36
Oiling in rotating pipe Brozicek STAR-CCM+ 2 September 6, 2016 11:45
Pipe Flow Simulation comingdaytime OpenFOAM Running, Solving & CFD 3 July 27, 2016 11:40
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
