[solids4Foam] compound has already been transfered from token |
September 22, 2021, 05:40 |
Denis Maier
Rep Power: 7 |
Hey everyone,
For a time now, I noticed again and again that when using the fixedDisplacementZeroShear boundary conditions (or BC that are derived from it) the solver is not restartable. I always get a Error message similar to: Code:
compound has already been transfered from token on line 71955 the empty compound of type List<vector> In fixedDisplacementZeroShearFvPatchField.C in line 104: Instead of initializing the refValue with a new vectorField it should be initialized with the "totalDisp_" vectorField that was already initalized with the same arguments. Last edited by DOMaier; September 22, 2021 at 07:13. |
March 25, 2023, 01:18 |
Xiangjie Wang
Rep Power: 7 |
Hi Denis, did you find the solution? I am also having some similar problems.
Best, X |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 02:11 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Field Mapper- Mesh refinment | mm.abdollahzadeh | OpenFOAM Programming & Development | 2 | January 24, 2013 09:18 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
