Describing necking/strain softnening in solids4FOAM |
April 2, 2021, 14:48 |
Rep Power: 6 |
Hello to all,
I would like to know if it is possible to describe strain softening in solids4Foam. The material I am using as some strain softening after yield (not has pronounced as in the image above) followed by strain hardening. I would like to input this behavior in solids4Foam. Can I just place the true stress- true strain curve in a file like in the neckingBar tutorial? What is the best approach to model this behavior? If I model strain hardening, does the first value of hardening need to be higher than the yield stress? Best Regards! |
November 24, 2021, 13:06 |
Philip Cardiff
Rep Power: 34 |
Yes you can just replace the true yield stress- true plastic strain curve, although softening may lead to unstable localisations and possibly mesh sensitivity. The current approach may be OK for your purpose, otherwise special procedures may be required to avoid mesh sensitivity e.g. https://www.researchgate.net/publica...7abAKQk0h9zPFQ. Philip |
[solids4Foam] solids4Foam installation | Deep1994 | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 42 | April 28, 2023 04:00 |
[snappyHexMesh] snappyHexMesh using foam-extend. Tag in boundary file (related with solids4foam) | ramrebol | OpenFOAM Meshing & Mesh Conversion | 5 | December 29, 2021 11:33 |
[solids4Foam] Multiple materials in solids4Foam | sdre | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 2 | February 2, 2021 05:51 |
From fsiFoam to solids4Foam | paulbr | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 7 | December 9, 2019 08:29 |
[FSI] solids4Foam vs icoFsiElasticNonLinULSolidFoam on HPC server | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 7 | August 31, 2019 06:26 |
