Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] fsifoam mismatching faces problem
Old   March 9, 2021, 22:21
Default fsifoam mismatching faces problem
han
oranjesr is on a distinguished road
Hi,there
I am creating solid and fluid meshes with blockMesh, adapted from the tutorials beamInCrossFlow, however, when I change the beam thickness to certain small value, the faces become mismatch.
I also try 10 times size of the all metioned mesh, problem still exists.
I believe there is a relative coefficient of the interface to the global size of the fluid mesh, to enable large displacement of solid interface to move in a timestep.
but I cannot figure out where it is, and how can I modify it??
here is the log for mismatching face. seems like a fluid face belongs to the interface-zone find the wrong solid face
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
Reading stress mesh
Creating traction displacement boundary conditions
Creating fixed displacement boundary condition
Selecting rheology model linearElastic
Creating constitutive model
Selecting coupling scheme Aitken
Starting time loop
Time = 0.0005
Create extended GGI zone-to-zone interpolator
Checking fluid-to-solid face interpolator
Fluid-to-solid face interpolation error: 0.05
Checking solid-to-fluid point interpolator (GGI)
Extended GGI, master point distance, max: 0, avg: -0.0457143, min: -0.1
Extended GGI, master point orientation (<0), max: 1, min: -1, nIncorrectPoints: 32/70
Solid-to-fluid point interpolation error (GGI): 0.1
Number of uncovered master faces: 0
Number of uncovered slave faces: 0
And if I only change the thickness of the beam to a big value,and keep the other mesh size still.
Create time
Reading stress mesh
Starting time loop
Time = 0.0005
Fluid-to-solid face interpolation error: 2.22478e-16
Extended GGI, master point distance, max: 0, avg: 0, min: 0
Extended GGI, master point orientation (<0), max: -0.707107, min: -1, nIncorrectPoints: 0/82
Solid-to-fluid point interpolation error (GGI): 2.30555e-16
oranjesr is offline   Reply With Quote
fsifoam
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
