[solids4Foam] reg complex eigen values warning |
August 4, 2020, 02:54 |
Rep Power: 16 |
I am using solids4Foam on a complex geometry with unstructured mesh. At the start of the run, I see warning message just after the line Solving the momentum equation for D "From function eigenValues(const tensor&) in file primitives/Tensor/tensor/tensor.C at line 180. complex eigenvalues detected for tensor: (1.23245e-06 -3.49791e-16 -4.16662e-14 -3.49791e-16 1.23245e-06 4.16674e-14 -4.16662e-14 4.16674e-14 1.2207e-06)". There are many such warning messages. What could be the reason for this? The solution did not converge even after 10000 iterations in the momentum loop. The solution tolerance is set to 1e-6. How does this affect the solution? Thanks Last edited by Barry; August 4, 2020 at 04:04. |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
Problem with complex eigenvalues detected for symmTensor | tbao | OpenFOAM | 3 | November 3, 2016 10:24 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? | randomid | OpenFOAM Community Contributions | 1 | August 27, 2010 06:15 |
