[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? |
May 29, 2020, 04:12 |
Sultan Islam
Rep Power: 11 |
Dear peeps,
So i installed solids4Foam with no issues on foam extend 4.1. I am currently running the lamina version of HronTurekFsi3 and its pretty slow (I dont know if its normal). I am 24 minutes in and only at around time step 2.006. I am running it on opensuse tumbleweed vm giving 6 core of i7 7700HQ. I notice that my cores alternate between 1 to 6, so sometimes core 4 gets 100% and sometimes its 1 or 6. But its never 100% for all 6? Is that normal? Also my terminal shows this: Code:
localhost:/home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar # ./Allrun Running blockMesh on /home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar cat: system/fvSchemes: No such file or directory cat: system/fvSolution: No such file or directory Running setsToZones on /home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar cat: system/fvSchemes: No such file or directory cat: system/fvSolution: No such file or directory Running blockMesh on /home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar cat: system/fvSchemes: No such file or directory cat: system/fvSolution: No such file or directory Running setsToZones on /home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar cat: system/fvSchemes: No such file or directory cat: system/fvSolution: No such file or directory Running solids4Foam on /home/a.i-workstation/Documents/OpenFOAM/OpenFOAM-Extend4.1/Run/Solids4FoamTutorial/fluidSolidInteraction/HronTurekFsi3/laminar cat: system/fvSchemes: No such file or directory cat: system/fvSolution: No such file or directory |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 05:38 |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 12:59 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 12:05 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
