HronTurekFsi does not run with more than 8 cpu's |
May 28, 2020, 09:26 |
Peter Knapen
Rep Power: 17 |
Gents,
I have a new computer with AMD 3950X processor (16 cores) and 64 GB memory. I have installed foam-extend 4.1 from source under Ubuntu 20.04LTS, gcc/g++ version 7 When I run HronTurekFsi with AllrunPar, I can change the decompaseParDict files upto 8 domains for fluid and solid and the anaysis does run. However when I try more than 8 regions/processors , say 16, I get following messages:Running fluent3DMeshToFoam on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid Running changeDictionary on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid Running setSet on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid Running setsToZones on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid Running decomposePar on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid Running fluent3DMeshToFoam on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/solid Running changeDictionary on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/solid Running setSet on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/solid Running setsToZones on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/solid Running decomposePar on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/solid changing into fluid directory creating links creating processor links Running icoFsiElasticNonLinULSolidFoam in parallel on /home/pk28831/foam/pk28831-4.1/run/HronTurekFsi2/HronTurekFsi/fluid using 16 processes and nothing happens anymore Is there somewhere an environment variable to be set for more than 8 cpu's? Best regards, Peter Setting the variable nCellsInCoarsestLevel to 10 instead of 20 in fvSolution did the job Last edited by peterk; June 9, 2020 at 11:04. Reason: solved |
CFDEMcoupling run: two identical runs have different error messages | minzhang | OpenFOAM Running, Solving & CFD | 0 | April 24, 2020 14:17 |
[OpenFOAM.org] paraFoam Fatal Error upon run | Gallienus | OpenFOAM Installation | 2 | April 14, 2020 20:23 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 07:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 12:20 |
How to run ".def" model with parallel CPUs | mohammad | CFX | 5 | January 10, 2011 19:00 |
