Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] newMovingWallVelocityFvPatch algorithm
Old   January 9, 2020, 03:26
Default newMovingWallVelocityFvPatch algorithm
Hojatollah Gholami
Hgholami is on a distinguished road
Dear Foamer
In the source code of newMovingWallVelocityFvPatch, I saw
forAll(Fc_, i)
Fc_[i] = patch().patch()[i].centre(points);
That seen save position of each center of patch boundary in Fc variable, then base on ddtScheme "Euler" calculate velocity base on difference of two position in old time and present time divided to deltaT.
Up = (Fc_ - oldFc_)/mesh.time().deltaT().value();
For ddtScheme "backward", it also use old.old.Time.
finally replace normal direction of velocity with phi
scalarField phip =
p.patchField<surfaceScalarField, scalar>(fvc::meshPhi(U));
vectorField n = p.nf();
const scalarField& magSf = p.magSf();
scalarField Un = phip/(magSf + VSMALL);
Up += n*(Un - (n & Up));
Do you confirm my realize?
Hgholami is offline   Reply With Quote
Development of PISO Algorithm Roger9318 Main CFD Forum 1 September 12, 2018 08:51
rhoSimplecFoam - which algorithm is implemented - references Manuel CFD OpenFOAM Programming & Development 7 September 8, 2014 08:28
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 04:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 14, 2007 00:17
