Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Static analysis with contact boundary
Old   November 28, 2019, 17:58
Default Static analysis with contact boundary
Manuel Oliveira
ManuelOliveira is on a distinguished road
Hello to everyone,
I am fairly new to OpenFoam and I would like to solve the problem described bellow.
The case I want to solve appear to be similar to the punch tutorial in solids4Foam (although I cannot run it via Allrun)
I have the following problem (in attachment):
Contact between two rectangular prisms with static load:
A static load of 2MPa is applied to the top face of the first prism. The remainder of it is set to solidContact.
Underneath the first prism is another one. Both solids are made of the same material. The top face is set to solidContact, the walls to solidTractionFree and the bottom to fixedDisplacement (0 0 0).
When I try to run it gives me unrealistic values in both stress and strain and I do not see the mistake.
What am I doing wrong?
Best Regards!
p { margin-bottom: 0.25cm; line-height: 115%; background: transparent none repeat scroll 0% 0%; }
ManuelOliveira is offline   Reply With Quote
Old   December 4, 2019, 13:32
Manuel Oliveira
Solved it.
Had to activate :
relaxationFactors
        D    0.999;
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
