Bruno Ramoa
Rep Power: 6 ![]() |
I am running a simulation with solids4Foam in Foam-extended 4.0. I stopped the simulation at a given time step and tried to restart it. In the control dict I am specifying for the simulation to start at the latest time, however, I am getting the following error: Code:
application solids4Foam; startFrom latestTime; startTime 0; stopAt endTime; endTime 80e-3; deltaT 9.57301e-7; Code:
--> FOAM FATAL ERROR: compound has already been transfered from token on line 341047 the empty compound of type List<vector> From function token::transferCompoundToken() in file lnInclude/token.C at line 95. FOAM aborting Aborted (core dumped) Best Regards! |
Ali Shayegh
Rep Power: 10 ![]() |
solids4foam |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 04:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
