[solidMechanics] Coulomb friction boundary condition without contactModels |
August 29, 2019, 11:18 |
Denis Maier
Rep Power: 7 |
Hey all,
I am working on the poro-elastoplasitc solvers by Tian Tang. For a multitude if situations concerning geotechnical problems I need to specify a friction boundary condition. The BC should either specify the displacement or traction (depending on the situation) for the normal component of the DU field. For the tangential component DU should be 0 as long as the resulting shear stress doesn't exceed the maximum value given by Coulomb's friction law (maxShear proportional to normal traction). If it does exceed, it should chance to a fixed (tangential) traction BC for that face and iteration. I was looking at the solidContact Boundary condition, but i think it is a bit overkill for what i need, since i dont need the ability of detachment and re-attachment of the material (yet). So i was thinking, I should be able to build on the fixedDisplacementZeroShear BC. However i can not seem to find where the tangential components are specified. I think the confusion stems from the whole valueFraction-issue that is quite hard to get the head around at the start. Can someone point me to the right lines in the fixedDisplacementZeroShear to modify? Greetings Denis |
August 29, 2019, 11:22 |
Update on coulombFrictionBC
Denis Maier
Rep Power: 7 |
I managed to gain a little bit more insight in how the boundary condition works, in that i now understand that valueFraction is a Tensor(Field) that tells me the mixture of fixedValue and fixedGradient in all directions. (I dont know if thats common practice but thats a beautiful solution)
so then I altered the updateCoeffs() function like this: void fixedSoilDisplacementCoulombShearFvPatchVectorFiel d::updateCoeffs() { if (this->updated()) { return; } vectorField n = patch().nf(); //face normals const fvMesh& mesh = patch().boundaryMesh().mesh(); //mesh reference const volSymmTensorField& sigmaV = mesh.objectRegistry::lookupObject<volSymmTensorFie ld>("sigma"); // (effective) stress field label patchID = patch().index(); symmTensorField sigmaP = sigmaV.boundaryField()[patchID]; // stress boundary field vectorField t = sigmaP & n; // traction on boundary scalarField smallField = scalarField(SMALL, sigmaP.size()) ; scalarField nt = (t & n) + smallField ; // normal traction magnitude vectorField st = t - ((t & n) * n) ; // shear traction vectorField tt ; forAll(patch(),iface) { if (mag(st[iface]) > (muFric_ * nt[iface])) { this->valueFraction()[iface] = sqr(n[iface]); // fixedValue only in n-direction tt[iface] = (st[iface]/mag(st[iface])) * (muFric_ * nt[iface]); // friction traction } else { this->valueFraction()[iface] = I; // fixedValue in all directions tt[iface] =0; // won't get used } } bool incremental_ = 1; scalarField pp = scalarField(sigmaP.size(), 0.0); // gradient in DU for given traction refGrad() = soilTractionBoundaryGradient::snGrad ( tt, //traction pp, //pressure fieldName_, "U", patch(), orthotropic_, nonLinear_, incremental_ ); directionMixedFvPatchVectorField::updateCoeffs(); } What do u think about that, would that give me what i want or am I on a wrong track? the scalar muFrac is read from dictionary as private data It complies nicely but i get a segmentation error when running a simple case with the BC.. Probably i missed a pointer to data conversion somewhere? |
August 29, 2019, 14:00 |
Philip Cardiff
Rep Power: 34 |
I can see one possible cause of the segmentation fault, coming from the following line: Code:
vectorField tt ; Code:
vectorField tt(sigmaP.size(), vector::zero); Code:
scalarField smallField = scalarField(SMALL, sigmaP.size()) ; Code:
scalarField smallField = scalarField(sigmaP.size(), SMALL) ; I would also add a SMALL to the division when calculating the shear traction direction to avoid a floating point, and change "= 0" to "= vector::zero": Code:
forAll(patch(),iface) { if (mag(st[iface]) > (muFric_ * nt[iface])) { this->valueFraction()[iface] = sqr(n[iface]); // fixedValue only in n-direction tt[iface] = (st[iface]/(mag(st[iface]) + SMALL)) * (muFric_ * nt[iface]); // friction traction } else { this->valueFraction()[iface] = I; // fixedValue in all directions tt[iface] = vector::zero; // won't get used } } Philip |
September 5, 2019, 10:29 |
Denis Maier
Rep Power: 7 |
thank you a lot for the helpful remarks!
the last few days i was testing out the BC and i was making some minor changes. The problem i have right now is that i get a snapping behavior of the friction boundary. I think it comes from the fact, that i use the stress field from the old time step to determine the frictional stresses. However, in the meantime i solved the DU-Eqn which is leading to a knew stress field. Calculating an intermediate stress field and using that one to determine the frictional stresses destroys convergence of the solution completely. Underrelaxation of the "intermediate" stress field doesn't help either. Do you know how that problem is solved or different in the solidContact boundary? |
September 5, 2019, 10:51 |
Philip Cardiff
Rep Power: 34 |
Hi Denis,
solidContact calculates the current stress and the friction condition is based on this; however, it uses a so-called penalty formulation (even stuck faces slip a small numerical amount) and does not use the valueFraction field. But my feeling is that it should be possible to get it to converge using your approach; you may need to relax the valueFraction field as well as the value of the friction stress. Small under-relaxation values may be needed e.g. 0.01. Philip |
geotech, solid |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Accessing multiple boundary patches from a custom boundary condition file | ripudaman | OpenFOAM Programming & Development | 0 | October 22, 2014 19:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
