Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
InterFace mismatch in solids4Foam toolkit for HronTurekFSI3
Like Tree14Likes
Old   March 6, 2020, 08:27
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
globalFaceZones should no longer be created and so the "setSet" and "setsToZones" commands are no longer needed; and also globalFaceZones should not be specified in the decomposeParDicts.
Try the following tutorial in parallel and let me know if it works:
$> cd tutorials/fluidSolidInteraction/beamInCrossFlow/linearGeometryElasticBeam
$> ./Allrun parallel
You can add the same "parallel" option to the Allrun script of other FSI cases but also make sure to remove globalFaceZones from the decomposeParDicts; I will update the HronTurek3 case.
Philip
Daniel_Khazaei likes this.
bigphil is offline   Reply With Quote
Old   March 6, 2020, 15:57
Daniel
Daniel_Khazaei will become famous soon enough
Originally Posted by bigphil View Post
Philip
Hello Dr. Cardiff,
On my Ubuntu system I had to change sh to bash in order to get the command line input "parallel" recognized by the Allrun script.
#!/bin/sh
to
#!/bin/bash
bigphil likes this.
Daniel_Khazaei is offline   Reply With Quote
Old   March 7, 2020, 00:38
thegauravonline's Avatar
GS
thegauravonline is on a distinguished road
Philip
O great!
Yes, It works well and good now.
Thanks
bigphil likes this.
thegauravonline is offline   Reply With Quote
Old   November 7, 2020, 13:01
Default Hi dear
  #24
Komeil Samet
Komeil is on a distinguished road
I'm using OFv7 but unfortunately I don't have fluidSolidInteraction file in my tutorials!!! Where can I find it?
Philip
Komeil is offline   Reply With Quote
Old   November 7, 2020, 14:05
Sita Drost
sita is on a distinguished road
Hi Komeil,
How did you end up posting in this thread? You still seem to be looking for a fluid structure interaction toolbox, like earlier in this thread (#33)
As I tried to point out in my previous answer, solids4Foam would be a useful option for you, but it runs under foam-extend-4.0 and not (yet) under OF7.
If you take a look at this presentation you'll find instructions on how to obtain solids4Foam, plus some worked tutorial cases and a lot of background information.
Hope this helps,
Sita
bigphil and Komeil like this.
sita is offline   Reply With Quote
Old   November 8, 2020, 15:51
Default Thanks
  #26
Komeil Samet
Hi dear Rita
Thank you so much, I'm going to read them.
Originally Posted by sita View Post
Hi Komeil,
Hope this helps,
Sita
Old   November 8, 2020, 15:54
Komeil Samet
Excuse me dear friend My mean was Sita
Thanks again
Sincerely yours
Komeil
Old   September 17, 2024, 13:55
Default FATAL ERROR in solids4foam-v2.1 for HronTurekFSI3
  #28
Gunther_123 is on a distinguished road
Dear Foamers,
I recently used solids4foam-v2.1 with fe41 on Ubuntu 18.04. All I did was copy the tutorial and run "AllrunPar". It started running but then stopped with the following messages:
Time = 0.6, iteration: 3
Current fsi under-relaxation factor (Aitken) of interface: 1
Maximal accumulated displacement of interface 0: 1.65297
DICPCG:  Solving for cellMotionUx, Initial residual = 0.789012, Final residual = 0.00619405, No Iterations 6
DICPCG:  Solving for cellMotionUy, Initial residual = 0.728419, Final residual = 0.00498668, No Iterations 5
DICPCG:  Solving for cellMotionUz, Initial residual = 0.706613, Final residual = 0.00429982, No Iterations 5
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] face 221 area does not match neighbour by 0.102876% -- possible face ordering problem.
patch: procBoundary0to1 my area: 0.000655687 neighbour area: 0.000656362 matching tolerance: 1
Mesh face: 23102 vertices: 4((0.798128 0.373697 -0.025009) (0.797923 0.399995 -0.0250086) (0.798684 0.399815 2.11284e-07) (0.798464 0.373689 2.57686e-07))
Rerun with processor debug flag set for more information.
[0]
[0]     From function processorPolyPatch::calcGeometry()
[0]     in file [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] face 221 area does not match neighbour by 0.102876% -- possible face ordering problem.
patch: procBoundary1to0 my area: 0.000656362 neighbour area: 0.000655687 matching tolerance: 1
Mesh face: 23006 vertices: 4((0.798128 0.373697 -0.025009) (0.798464 0.373689 -3.2819e-07) (0.798684 0.399849 -1.00767e-06) (0.797923 0.400017 -0.0250086))
[1]
[1]     From function processorPolyPatch::calcGeometry()
[1]     in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 246.
[1]
FOAM parallel run exiting
[1]
[0]
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[gunther-All-Series:25029] 1 more process has sent help message help-mpi-api.txt / mpi-abort
Can anyone help me? Thanks in advance.
Gunther
Gunther_123 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
