Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] Dynamic Mesh Problem for FSI simulation
Like Tree21Likes
Old   March 20, 2019, 01:38
Hojatollah Gholami
Hgholami is on a distinguished road
Dear popa
I uses similar version (fe40). the stress saves in solid folder of each timeStep as "sigma".
I copy all file in HronTurekFsi/fluid/timeStep(ex. 12.04)/solid folder to HronTurekFsi/solid/(create) timestep (ex. 12.04) and then uses foamToVTK -latestTime.
Only the problem is the stress will shows in initial state of solid mesh. Unfortunately I can't find any points for solid region to use that.
Hgholami is offline   Reply With Quote
Old   March 20, 2019, 07:58
Default what do you mean
  #22
popa is on a distinguished road
Originally Posted by Hgholami View Post
I dense mesh and reduce flexibility of structure. Now, the problem is solved.
Thanks for your favor
Could you provide your steps in detail?I meet the same problem.About the refine mesh.
popa is offline   Reply With Quote
Old   March 20, 2019, 08:10
Default a way to do it
  #23
Dear popa
About any points for solid region to use,someone said that "go to the main file of the solver, then find the ID of the point you want to monitor, and then you can output it in several time steps",but i doesn't find the way,and the people doesn't answer me anymore.
Old   March 20, 2019, 08:40
Daniel
Daniel_Khazaei will become famous soon enough
Do you want to monitor the stress of a point located inside your solid region?
Then there is a function object dedicated for this purpose in solids4Foam toolbox: solidPointStress function object
You can send a pm to Dr.Cardiff (bigphil) and he will provide you with access to the toolbox.
That approach about modifying your solver to output the stress value of a specific point based on its cell ID does also work correctly but using function object is a way to go if you need portability and cleaner code.
bigphil likes this.
Daniel_Khazaei is offline   Reply With Quote
dynamic mesh, fsi
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? Pol.P FLUENT 9 March 7, 2022 18:21
OpenFOAM - mixing tank simulation using dynamic mesh foamF OpenFOAM 3 February 9, 2021 16:43
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
Dynamic Mesh Problem peatmac FLUENT 9 March 14, 2012 07:11
problem about dynamic mesh of VOF model whpsoft FLUENT 0 September 9, 2005 00:06
