Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] fsiFoam installation problem
Old   May 31, 2017, 13:16
Default fsiFoam installation problem
Wei Meng
Tomko is on a distinguished road
Hi guys,
I have a little question about the installation of fsiFoam. I read the installtion instructions about the fsiFoam from this links: http://openfoamwiki.net/index.php/Ex...oam-extend_4.0
My question is: is the fsiFoam built on foam-extend? Do I need to install foam-extend before I install fsiFoam? What is the relation between foam-extend and OpenFoam?
My OpenFoam version is v1612.
Waiting for the reply and Thank you very much!
Tomko is offline   Reply With Quote
Old   June 4, 2017, 18:00
Retired Super Moderator
Bruno Santos
Quick answers:
Old   July 13, 2017, 13:04
Wei Meng
Hi Bruno,
Thank you very much for your kind reply!
My problem now is the 'wmake' command gave me lots of 'could not open file xxx for source file xxx ' during the fsiFoam installation process.
If my understanding is correct, my both OpenFOAM+(v1612) and foam-extend-4.0 are forks, and they cannot coexist in the same shell environment. Therefore, I should follow the instruction of https://openfoamwiki.net/index.php/I...nFOAM_versions to solve this, right?
I have tested the tutorials of both my openFOAM(v1612) and foam-extend-4.0, and they all run well. My only problem is always fail to install the fisFoam on foam-extend-4.0, which really drive me crazy...
By the way I did all of these on Windows.
Looking forward to you reply! Thanks!
Old   July 13, 2017, 17:34
Wei Meng
Hi Bruno,
Sorry for reply again. I have tried the above method, but the fsiFOAM still can not be compiled/built.
By adding the code:
alias fe40='source /openfoam/foam-extend-4.0/etc/bashrc'
to the bashrc file and enter the command 'fe40'.
I am sure the foma-extend-4.0 is on the surface. By this way I built (./Allwmake) the fsiFoam in the foam-extend-4.0 shell environment.
But same errors like these still showed up.
log:
make: *** [Make/mingwGccDP0pt/RBFInterpolation.o] Error 1
Making dependency list for source file fsiFoam.C
could not open file boolList.H for source file fsiFoam.C
could not open file HashSet.H for source file fsiFoam.C
could not open file Map.H for source file fsiFoam.C
could not open file EdgeMap.H for source file fsiFoam.C
could not open file primitiveMeshI.H for source file fsiFoam.C
could not open file pointIOField.H for source file fsiFoam.C
could not open file faceIOList.H for source file fsiFoam.C
could not open file label1IOList.H for source file fsiFoam.C
could not open file ployBoundaryMesh.H for source file fsiFoam.C
could not open file pointZoneMesh.H for source file fsiFoam.C
could not open file faceZoneMesh.H for source file fsiFoam.C
could not open file cellZoneMesh.H for source file fsiFoam.C
could not open file lduMesh.H for source file fsiFoam.C
could not open file fvBoundaryMesh.H for source file fsiFoam.C
could not open file surfaceInterpolation.H for source file fsiFoam.C
could not open file DimensionedField.H for source file fsiFoam.C
But all of these files can be found in my '/openfoam/foam-extend-4.0/src/foam'
How can I let the fsiFoam compiling program find the right location of these files and open them?
Looking forward to your reply!
Old   July 14, 2017, 15:01
Wei Meng
Originally Posted by wyldckat View Post
Quick answers:
Hi Bruno,
Sorry to bother again...
I found you've help to solve a similar problem like mine in Trouble compiling utilities using source-built OpenFOAM
Unfortunately, that is not my case.
I tried to see the path of WMAKE_BIN by the code:
ls -l $WM_DIR/bin/$WM_ARCH$WM_COMPILER
It returns:
-rwxr-xr-x l lenovo Administrations 47164 Jun l 20:23 dirToString.exe
-rwxr-xr-x l lenovo Administrations 73820 Jun l 20:23 wmkdep.exe
I don't have the 'wmkdepend' term, so his solution seems not work for me.
It would be great help if you have time to help look through this.
Best Reagards,
Wei
Problem in case HronTurekFsi3 (fsiFoam) lxwd OpenFOAM Running, Solving & CFD 2 January 23, 2017 08:02
Problem with installation florvit ANSYS 0 December 8, 2016 10:10
[OpenFOAM.com] Installation Problem Manyway OpenFOAM Installation 2 July 8, 2016 14:47
Installation problem - calling blockMesh - libblockMesh.so aylalisa OpenFOAM Installation 5 November 28, 2012 10:55
ParaView installation problem on Suse 11.4 victorz OpenFOAM Installation 4 February 6, 2012 18:26
