May 15, 2017, 05:45 |
FSI + Rigid body impact
Lucas Ribeiro
Rep Power: 10 |
Hello folks,
I have extended the Fluid-Solid Interaction toolkit[Tuković at al] of foam-extend 3.1 to support nonNewtonian fluids. The implementation is verified and is correct. Now, I would like to simulate an impact using it. A hemispherical impactor would fall impacting on a brick made of elastic material with non-Newtonian fluid confined inside of it. The impactor is made of steel and is would be modeled basically as a rigid body. How could I simulate the impact between a rigid body and the already implemented elastic material? Does anyone has a guideline? Or just a starting point? The concept: Thanks |
February 9, 2019, 21:35 |
Andrew O. Winter
Rep Power: 11 |
Hello Lucas,
It's been some time since you posted this so I'm wondering if you made any progress towards your goal? If so, could you give some direction as to how you either used existing OpenFOAM functionality and/or added new code on your own to make things work? I'm thinking of trying to simulate rigid bodies colliding with one another and in the future moving towards elastic bodies; however, as far as I can tell this sort of functionality is not available at present in OpenFOAM. Best regards, Andrew |
February 11, 2019, 07:22 |
#3 | ||
Lucas Ribeiro
Rep Power: 10 |
Hello Andrew,
Best regards, Lucas |
July 29, 2022, 09:40 |
Ashish Magar
Rep Power: 10 |
Hi Lucas,
Have you made any progress in this regard? Also isn't solids4Foam based on FVM, do you know any open source libs based on FEM to be used for impact simulations? Thanks |
fsi, impact, projectile, rigid bodies |
6-DoF Rigid Body Motion | jumpa72 | OpenFOAM Running, Solving & CFD | 6 | March 1, 2024 03:38 |
Two Way FSI of Highly Flexible Body | Sunny Chitti | Structural Mechanics | 0 | June 27, 2017 15:22 |
force convergence problems in CFX 6DOF rigid body solver | ajay_ks | CFX | 8 | March 25, 2013 05:02 |
Rigid body fsi | akash1016 | FLUENT | 0 | August 19, 2012 09:19 |
Rigid body | Birkov | CFX | 4 | May 25, 2012 07:26 |
