Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Overall displacement constraint for solidMechanics
Old   April 3, 2015, 05:14
Default Overall displacement constraint for solidMechanics
Stanislav
anotherche is on a distinguished road
What possibilities exist in OF to apply an overall displacement constraints in steady-state solid mechanics problems in general cases (say if we have no symmetry)? In ansys there are variants to apply displacement constraints in points and planes which are sufficient to prevent undefined large displacements. What is about OF?
Specifically I try to use foam-extend-3.1 to solve a thermal stress problem in 2D. Thin plate with a surface crack loaded with a non-uniform temperature field alone defined with the help of funkySetFieldsDict; all the surfaces are free of traction. In my case there is only one face to which the symmetryPlane condition can be applied (a neck in front of the crack). So displacement is constrained in direction of normal to the symmetryPlane face only. It would be ideal to apply a fixed zero displacement in any point on that face. But how to? The only method I found in this forum is to define a small subsection on that face.
anotherche is offline   Reply With Quote
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Why I can't constraint the radial displacement in a periodic model? loveHL STAR-CCM+ 2 May 21, 2014 12:43
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 03:04
how to use Total Mesh Displacement for making a subject translating and rotating? snailstb CFX 3 September 16, 2009 05:06
