[solidMechanics] a defect of solidMechanics in foam-extend-3.0 |
June 3, 2014, 07:57 |
xuhe-openfoam
Rep Power: 13 |
hi,
I found a defect of solidMechanics in foam-extend-3.0 ! for example , I created a myelasticNonLinULSolidFoam just changing the elasticNonLinULSolidFoam from Code:
Info<< "Reading accumulated displacement field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh, dimensionedVector("zero", dimLength, vector::zero) ); Code:
Info<< "Reading accumulated displacement field U\n" << endl; volVectorField Usolid ( IOobject ( "Usolid", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh, dimensionedVector("zero", dimLength, vector::zero) ); then, wmake to get the myelasticNonLinULSolidFoam ! and I created a case that replace U by Usolid too ! when we use this new solver to run a case which needs to use the accumulated displacement field(for example use the timeVaringFixedDisplacement boundary) , it will be error Code:
Starting time loop Time = 0.01 --> FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed available objects of type volVectorField are 5 ( Usolid DUPrevIter DU divDSigmaLargeStrainExp divDSigmaExp ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/sxh/foam/foam-extend-3.0/src/foam/lnInclude/objectRegistryTemplates.C at line 139. FOAM aborting actually , I first found this problem in the icoFsiElasticNonLinULSolidFoam which use Usolid instead of U in solid part , for there is a U in fluid part ! I don't know what is wrong . maybe it is a bug ? what do you think ? thanks |
June 3, 2014, 09:29 |
Philip Cardiff
Rep Power: 34 |
Many of the solid mechanics boundary conditions (in $FOAM_SRC/solidModels/fvPatchFields) expect the displacement field to be called "U", and have this hard-coded into the boundary condition. So you would need to modify the specific boundary condition if you want to change the name of the displacement field, or add an optional variable to the boundary condition definition giving the name of the displacement field. Best regards, Philip |
solidmechanics |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
