[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" |
February 23, 2022, 08:30 |
#661 |
Merlin Williams
Rep Power: 5 |
Yes, of course the dimensions show what pressure it is. That was silly.
Ohh I see. Is there functionality in cfMesh or snappyHexMesh to be able to specify the surface level mesh on the fluid interface to triangular whilst keeping the main internal fluid domain hexahedral? Or would it involve changing the whole fluid domain mesh to tetrahedral and then extruding the solid domain to create the triangular prism elements? Merlin Last edited by MFWilliams; February 23, 2022 at 11:01. |
February 23, 2022, 13:06 |
#662 | ||
Philip Cardiff
Rep Power: 34 |
For cfMesh, you can use tetMesh or pMesh instead of cartesianMesh, but as you noted, this will change the internal fluid mesh too. It is possible to create a utility to split all surface faces into triangles but I don't think this exists and some non-trivial coding would be involved. So your options would be to use a set mesh for the fluid and then extrude the solid as triangular prisms. Or use this same triangular prism solid mesh with the original Cartesian fluid domain (non-conformal interface). |
February 24, 2022, 07:15 |
#663 |
Merlin Williams
Rep Power: 5 |
Brilliant thank you very much for clarifying that.
Merlin |
February 25, 2022, 07:14 |
#664 |
Merlin Williams
Rep Power: 5 |
For my FSI simulation, I am getting the warning "Max iterations reached within momentum loop". Is there a way to increase the number of iterations it can complete or do you know why this might be happening?
Thanks Merlin |
February 25, 2022, 07:45 |
#665 |
Philip Cardiff
Rep Power: 34 |
Set nCorrectors in constant/solid/solidProperties (or constant/solidProperties in a solid only case) to be a larger number, e.g. 1000, or 5000 or 10000.
February 25, 2022, 09:56 |
#666 |
Merlin Williams
Rep Power: 5 |
February 27, 2022, 11:15 |
#667 |
Merlin Williams
Rep Power: 5 |
If anyone is interested, I have greatly improved the oscillations in my FSI simulation by changing the BC for the pressure of the fluid on the fluid solid interface patch from a zeroGradient to extrapolatedPressure BC.
I am also having trouble with setting the coupling time to start later in the simulation and I was wondering if anyone had any ideas about it. I have a working FSI sim and I have tried changing the coupling start time to 0.01 seconds. But when I run it, it now breaks before it even gets to the coupling and the fluid velocities are much higher than they are when I have coupling from the start. I also have a working CFD sim which is exactly the same as the fluid for my FSI simulation and that has no problems. The log file of the broken FSI sim is here Does anyone know why specifying the coupling start time might cause problems? Thank you in advance for your help. |
March 1, 2022, 09:49 |
#668 | |
Iago Lessa de Oliveira
Rep Power: 11 |
This procedures leads to non-conformal meshes at the FSI interface, so you have to be carefull with using a sufficiently refined mesh, otherwise it may not even pass the GGI test at the beginning of the FSI simulation that checks the FSI interpolation errors. |
March 1, 2022, 10:33 |
#669 | |
Merlin Williams
Rep Power: 5 |
That was my bad misinterpreting what you saying about triangular prisms for meaning tetrahedral elements. Ok have you found there to be any sort of minimal functional ratio between the number of nodes on the fluid interface to nodes on the solid interface? Thank you for the help Merlin |
March 1, 2022, 11:02 |
#670 | |
Rep Power: 11 |
Iago |
May 7, 2022, 15:53 |
Problems with multi-domain multi-material simulation (elasticSolidFoam)
#671 |
Richardpluff
Rep Power: 12 |
Dear foamers,
Hope I am on the right place to get some tips about my simulation. I have been dealing with it for a long time and can't find the way to make it work. I am not a newcomer to OpenFOAM but never used it for solid mechanics problems and I would like to start doing it. I have a block and some teeth. I created my stls and divided them into load, support, lower_teeth and block. The idea would be to impose a load (solidTraction for example) once the geometry is clamped by the support (I would say fixedDisplacement equal to 0). Two different domains will be present (one for the block=bone, another one for the Lower_teeth=teeth), together with 2 different materials (bone and teeth). I used snappy for meshing. After enclosing my geometry in a block using blockMesh and meshing with snappy, I got 3 domains meshed. I needed to remove the one corresponding to the background, so I used setSet, subSetMesh and splitMeshRegions). Seems that it works (checkMesh is OK). New contacts (interfaces) between regions have been created. I define my material properties regions using materials file and cellstoRegion (renamed to have 0 and 1 indexes only). I remove everything related to the background mesh (like ffminx, ffmaxx...in boundary file, cellRegions...). I checked in Paraview and materials assignement has been carried out succesfully. I share here the case in One Drive (it is heavy, just in case you want to give a try to it): https://1drv.ms/u/s!AjenQBoiljuzgoQs...rRL4Q?e=fe5Pjf BCs are supposed to be a load on the load boundary and clamped support. I would like to know stress and deformations produced due to this load. When I run elasticSolidFOam, the simulations explodes after a few iterations (static analysis), with too high values of stress and strain. I tried many things (remesh, play with Bcs and numerical schemes, material properties or use only one material...) but nothing seems to work. Any hints on my set up? Mesh? BCs? Contacts? Also another remark is that I am unable to see the different mesh regions created in the former step (they can be imported in Paraview, but they do not contain U, V, sigma, epsilon...fields...). Why not? Only the whole internal mesh is populated with such values. @bigphil or any other guru here...could you please give me a hand on this? I apologise in advance if this is not the best place to open my thread... Thanks to all solid mechanics foam extend community! |
May 12, 2022, 16:28 |
solids4foam error building on fe35 aarch64
#672 |
Sultan Islam
Rep Power: 11 |
So im buiding solids4foam on fe35 for aarch64 using foam extend 4.1. I get an error when replacing solutions.c Code:
fe-aarch64OS localhost ../solids4foam-release cp filesToReplaceInOF/solution.C /home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/foam/matrices/solution/ fe-aarch64OS localhost ../solids4foam-release wmake libso /home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/foam Making dependency list for source file matrices/solution/solution.C SOURCE=matrices/solution/solution.C ; g++ -std=c++11 -DlinuxARM8 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -march=native -mtune=native -DNoRepository -ftemplate-depth=100 -DOMPI_SKIP_MPICXX -I/usr/local/OpenMPI-4.0.3/gcc-7/openmpi/include -fexceptions -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/foam/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxARM8GccDPInt32Opt/solution.o SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/4.1/' -e 's/BUILD_STRING/4.1-70b064d0f326/' $SOURCE > Make/linuxARM8GccDPInt32Opt/global.C; g++ -std=c++11 -DlinuxARM8 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -march=native -mtune=native -DNoRepository -ftemplate-depth=100 -DOMPI_SKIP_MPICXX -I/usr/local/OpenMPI-4.0.3/gcc-7/openmpi/include -fexceptions -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/foam/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxARM8GccDPInt32Opt/global.C -o Make/linuxARM8GccDPInt32Opt/global.o matrices/solution/solution.C:426:6: error: prototype for 'void Foam::solution::setSolverPerformance(const Foam::word&, const lduSolverPerformance&) const' does not match any in class 'Foam::solution' void Foam::solution::setSolverPerformance ^~~~ In file included from matrices/solution/solution.C:26:0: matrices/solution/solution.H:174:18: error: candidates are: template<class Type> void Foam::solution::setSolverPerformance(const Foam::BlockSolverPerformance<Type>&) const void setSolverPerformance ^~~~~~~~~~~~~~~~~~~~ matrices/solution/solution.H:166:18: error: template<class Type> void Foam::solution::setSolverPerformance(const Foam::word&, const Foam::BlockSolverPerformance<Type>&) const void setSolverPerformance ^~~~~~~~~~~~~~~~~~~~ matrices/solution/solution.C:462:6: error: prototype for 'void Foam::solution::setSolverPerformance(const lduSolverPerformance&) const' does not match any in class 'Foam::solution' void Foam::solution::setSolverPerformance ^~~~ In file included from matrices/solution/solution.C:26:0: matrices/solution/solution.H:174:18: error: candidates are: template<class Type> void Foam::solution::setSolverPerformance(const Foam::BlockSolverPerformance<Type>&) const void setSolverPerformance ^~~~~~~~~~~~~~~~~~~~ matrices/solution/solution.H:166:18: error: template<class Type> void Foam::solution::setSolverPerformance(const Foam::word&, const Foam::BlockSolverPerformance<Type>&) const void setSolverPerformance ^~~~~~~~~~~~~~~~~~~~ make: *** [matrices/solution/solution.dep:322: Make/linuxARM8GccDPInt32Opt/solution.o] Error 1 make: *** Waiting for unfinished jobs.... Edit 2: it seems that whatever changes the replaced solution.c does, is not valid for FE41, I don't know why the allcheck is even running them when its building from FE4.1 Edit 3: After install bg, solids4foam check script detected foam version correctly, howver now in the compilation, I have this errror: Code:
-L/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -llduSolvers -linterfaceProperties -lfiniteArea -loversetMesh -loversetDynamicFvMesh -lblockCoupledSolids4FoamTools -lsolids4FoamModels -lfiniteVolume -lincompressibleTransportModels -ldynamicFvMesh -ldynamicMesh -lmeshTools -ltopoChangerFvMesh -lfoam -ldl -lm -o /home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/mergeSubMeshesNew /usr/bin/ld: /home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt/libsolids4FoamModels.so: undefined reference to `__aarch64_ldadd4_acq_rel' collect2: error: ld returned 1 exit status make[1]: *** [/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/wmake/Makefile:160: /home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/mergeSubMeshesNew] Error 1 make: *** [/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/wmake/MakefileApps:39: mergeSubMeshesNew] Error 2 Last edited by EternalSeekerX; May 13, 2022 at 13:04. |
May 13, 2022, 09:32 |
#673 |
Rep Power: 6 |
Hi ,
have you solved your problem? |
May 13, 2022, 12:15 |
#674 | |
Philip Cardiff
Rep Power: 34 |
Can you give the full error? i.e. the log file from "Allwmake &> log.Allwmake" |
May 17, 2022, 00:51 |
Issue solved?
#675 | |
Sultan Islam
Rep Power: 11 |
Here is both fef41 log and solids4foam attached! I find it odd that it works now, i think. Only issue I see is the missing S4F for abaqus thingy Last edited by EternalSeekerX; May 17, 2022 at 05:58. |
May 18, 2022, 08:27 |
#676 |
Philip Cardiff
Rep Power: 34 |
OK, glad it works. No need to worry about the abaqus UMATs unless you actually plan to use them.
May 18, 2022, 22:57 |
abaqus UMAT compiled fine
#677 | |
Sultan Islam
Rep Power: 11 |
fe-aarch64OS localhost ../Solids4Foam ./Allwmake -j4 filesToReplaceInOF/Allcheck No checks for versions of foam-extend greater than 4.0 eigen3 found. Updating Make/files link Using Make/files.foamextend '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt/libblockCoupledSolids4FoamTools.so' is up to date. Updating Make/files link Using Make/files.foamextend '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt/libsolids4FoamModels.so' is up to date. wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file abaqusUmatLinearElastic/abaqusUmatLinearElastic.C SOURCE=abaqusUmatLinearElastic/abaqusUmatLinearElastic.C ; g++ -std=c++11 -DlinuxARM8 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -march=native -mtune=native -DNoRepository -ftemplate-depth=100 -std=c++11 -Wno-old-style-cast -Wno-deprecated-declarations -DFOAMEXTEND=41 -I../solids4FoamModels/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/finiteVolume/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/meshTools/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/finiteArea/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/lagrangian/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/dynamicMesh/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/dynamicMesh/dynamicMesh/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/dynamicMesh/topoChangerFvMesh/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/sampling/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/surfMesh/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/postProcessing/foamCalcFunctions/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/errorEstimation/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/ThirdParty/packages/metis-5.1.0/platforms/linuxARM8GccDPInt32Opt/include -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/decompositionMethods/decompositionMethods/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/decompositionMethods/metisDecomp/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/decompositionMethods/scotchDecomp/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/mesh/extrudeModel/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/applications/utilities/mesh/generation/extrudeMesh -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/applications/utilities/mesh/generation/extrudeMesh/extrudedMesh -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/applications/utilities/preProcessing/mapFields -IlnInclude -I. -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/foam/lnInclude -I/home/fe-aarch64OS/.root/opt/OpenFOAM/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxARM8GccDPInt32Opt/abaqusUmatLinearElastic.o '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt/libabaqusUmatLinearElastic.so' is up to date. Compiling abaqusUmatLinearElastic.f and placing object in /home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt Updating Make/files link Using Make/files.foamextend make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/solids4Foam' is up to date. Copying solids4FoamScripts.sh to /home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/abaqusMeshToFoam' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/addPatch' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/addTinyPatch' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/flattenPatch' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/decomposeParNew' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/projectPatchToSphere' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/mergeSubMeshesNew' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/set2dMeshThickness' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/setInitialTemperature' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/splitPatch' is up to date. '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/lib/linuxARM8GccDPInt32Opt/libsimpleMeshSmoothers.so' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/surfaceTractions' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/volPointInterpolate' is up to date. make[1]: '/home/fe-aarch64OS/foam/fe-aarch64OS-4.1/applications/bin/linuxARM8GccDPInt32Opt/simpleSmoothMesh' is up to date. solids4foam compilation complete; check for errors above fe-aarch64OS localhost ../Solids4Foam |
May 19, 2022, 15:31 |
Flexible Dam Break worked on aarch64 container
#678 |
Sultan Islam
Rep Power: 11 |
So, I tested the flexible dam break tutorial on my fedora 35 aarch64 container and it worked haha.
Here is a gif: https://giphy.com/gifs/AMRmCkVzNaP0XxdKcD |
August 5, 2022, 10:33 |
Impact test simulation using solids4Foam
#679 |
Ashish Magar
Rep Power: 10 |
Hello Philip,
I am doing a simplistic impact test simulation, where an object will be falling due to gravity on a fixed object. I took help from this post Bouncing ball to get started. However, the 'res' residuals are always 1 and only 'relRes' are converged. After a few time steps the simulation crashes with diverging relative residuals. Also I would like to mention, as per your suggestion I have only DD relaxation but cant see any rigid body motion. Is there any thing I am missing or doing wrong? |
August 5, 2022, 11:02 |
#680 | |
Philip Cardiff
Rep Power: 34 |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 15:22 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 17:01 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
