February 19, 2020, 06:50 |
#501 |
Torsten Schenkel
Rep Power: 12 |
Yes the new solvers in solids4foam seem to have lower numerical diffusion than the ones in the FluidSolidInteraction toolkit (bazaar). This is good, since I get a better match on the QNET-FSI validation case, which is a more realistic version of the Hron-Turek benchmark, based on experimental results. I get within 10% of frequency on a setup similar to the Hron-Turek benchmark tutorial, where the old FSI toolkit was struggling to get in the same regime. Unfortunately the new toolkit is a lot less stable (well, obviously, if it has lower diffusion), so the HronTurek benchmark is really tricky to get working. a) Underrelaxation helps, not only on D (i did not actually need to do that), but in the FSI underrelaxation (I went down by more of an order of magnitude), which is only used for the first three FSI loops, with the IQN method, then IQN takes over. But if the first loops are too far out, it won't converge. I set max FSI loops to 50, but it should converge within around 20-30, the 50 is just for the unruly timesteps. You have to check the FSI residuals, so I do a Code:
grep "FSI residual" solids4foam.logfile | tail -n 500 > FSI-residuals Code:
set logscale y set xlabel "Iteration" set ylabel "R" set grid plot "< tail -n 500 FSI-residuals | cut -d' ' -f7 | tr -d ','" title 'FSI Res' with lines ls 2 FSI_convergence.png And this one is not (that's two or three time steps leading up to the problem you describe): FSI_convergence_borked.png BTW, there may be an issue with the coupling, I do get weird artefacts in the structure of my QNET case: weird_artefacts.jpg Pressures are vertex values, sigma is cell based. Material model is unsNonLinearGeometryTotalLagrangian, StVenantKirchhoff (rho-1360, E 16e6, nu 0.48). The weird artefacts seem to be correlated with the mesh size on the fluid side. I can imagine that these could trigger instabilities in the solid solver. Last edited by tschenkel; February 19, 2020 at 07:06. Reason: add non-converged image |
February 19, 2020, 07:33 |
#502 | |
Torsten Schenkel
Rep Power: 12 |
February 19, 2020, 08:46 |
Material linearity enforced for stability
#503 |
Sita Drost
Rep Power: 18 |
Hi Torsten,
Thanks for the tip! Reducing the FSI under-relaxation by a factor of 10 didn't help, even in combination with under-relaxation of D, Deqn, DD, and DDeqn. But I'll play around with the settings a bit further, see if I can get things running. Regards, Sita EDIT: I'm at an FSI relaxation factor of 0.001 now, with under-relaxation of D, Deqn, DD, and DDeqn all at 0.5, but still no luck. I've tried both Aitken and IQNILS, but my run keeps crashing. I didn't think this would be such a hard case, Hron Turek FSI 1 (i.e. steady flow) with gravity in negative y (I wanted to test large deformation). Anything else I can try? Last edited by sita; February 19, 2020 at 11:04. |
February 19, 2020, 08:52 |
#504 |
Torsten Schenkel
Rep Power: 12 |
BTW, forgot to mention, the errors (or rather warnings about enforcing linear model) you get are no problem, if they go away in the final FSI loops. As long as the final loop is using the correct equations, the results should be fine.
February 19, 2020, 11:36 |
#505 | |
Philip Cardiff
Rep Power: 34 |
February 20, 2020, 10:54 |
#506 |
Sita Drost
Rep Power: 18 |
Hi Philip,
Thanks, that's good to now. For now I'm afraid premature convergence isn't a problem though; it looks like the solver uses the maximum number of iterations at each time step, without properly converging. Is there anything else I should try to get my case running properly? Many thanks, Sita |
February 24, 2020, 08:23 |
#507 |
Sita Drost
Rep Power: 18 |
Hi all,
I'm still struggling to get my case running (see previous posts), it keeps warning me that Material linearity was enforced for stability, and then crashes after a while. I've been trying to increase the number of iterations, using nIterations in unsNonLinearGeometryTotalLagrangianCoeffs, but it looks like that's not being picked up. What's the proper way to set the (maximum) number of iterations for unsNonLinearGeometryTotalLagrangian? Also, looking through the code for unsNonLinearGeometryTotalLagrangian, I noticed a parameter stabilisePressure, which is false by default. What's the function of stabilisePressure? Thanks in advance, Sita EDIT: After some more testing, I noticed that the coupling start time makes a difference. If I set it to t = 0 (i.e. coupled = yes), even the original Hron Turek FSI 1 case (steady deformation, no gravity) crashes fairly soon. This isn't the case in the old fsiFoam, does anyone know what's the difference? Setting the coupling start time to t = 0.1, the case runs alright for g = -2 m/s2, but still not for higher, more earth-like values. Any tips, anyone? Last edited by sita; February 27, 2020 at 03:19. |
February 26, 2020, 09:05 |
Strange damping in perfectly elastic materials
#508 |
Torsten Schenkel
Rep Power: 12 |
I'm looking into the HronTurek benchmark solids side of things and have discovered a strange damping. Setup is as per the tutorial case, but solid only (so CSM2 from the paper, but as a transient case): NeoHookean Material E = 5.6e6 nu = 0.4 rho = 1000 unsNonLinearTotalLagrangian Case description: Beam of length 0.6m and thickness (height) of 0.02m is fixed at the left side At t=0 the structure is released in a constant gravity field of (0 -9.81 0). The simulation runs nicely, but the oscillation is damped. If I understand correctly there should be no damping in this setup: - no fluid surrounding the structure, so no external damping - neoHookeanElastic or StVenantKirchhoffElastic material should be perfect elastic, so no internal damping So the only damping I can see can come from discretisation errors. I tried a finer mesh, which does improve things very slightly, and going from second order (linear) to third order (cubic): Code:
34c34,35 < default Gauss linear; --- > // default Gauss linear; > default Gauss cubicCorrected; 40,41c41,42 < laplacian(DD,D) Gauss linear newSkewCorrected 1; < laplacian(DDD,DD) Gauss linear newSkewCorrected 1; --- > laplacian(DD,D) Gauss cubic newSkewCorrected 1; > laplacian(DDD,DD) Gauss cubic newSkewCorrected 1; Am I missing something? damped_oscillation.png |
February 26, 2020, 11:01 |
#509 |
Philip Cardiff
Rep Power: 34 |
This damping comes from the time discretisation (d2dt2 and ddt).
Euler is only 1st order accurate. You should perform a time-step size sensitivity analysis, and may also try "backward" which is 2nd order accurate (but introduces a lot of dispersion errors). Either way, Euler with a very small time-step will show minimal time discretisation errors. Philip EDIT: FE methods often use trapezoidal or Newmark methods or some combination: these could be implemented Last edited by bigphil; February 26, 2020 at 11:03. Reason: See edit at bottom of post |
February 26, 2020, 11:37 |
#510 | |
Torsten Schenkel
Rep Power: 12 |
Thanks a lot, I am on backward already, so had thought d2t2 would be alright. Time step analysis was next on the list. As a fluid dynamicist, I have to ask a possibly stupid question: What is the solids equivalent to the Courant number? EDIT: It does require quite small time steps, but does work (reduced timestep from 1e-3 to 1e-4s). There is still a little bit of damoing, but it's a lot better: small_deltat.png Last edited by tschenkel; February 26, 2020 at 12:32. Reason: include results |
February 26, 2020, 12:18 |
#511 | |
Philip Cardiff
Rep Power: 34 |
The speed of sound in solids is typically higher than fluids so the wave speed is high; this means to stick to a Courant number of less than 1 requires very small time steps (especially as you refine the mesh). However, the stability of implicit solution methodologies (like in unsNonLinGeomTotalLag) does not depend on the Courant number. In contrast, explicit solution methodologies (like in explicitLinGeomSolid) do require the Courant to be less than 1 for stability. For your time sensitivity analysis, there is probably no need to approach the Courant number, although if you do use such a small time-step then the diffusion error due to the time-step size should be very small. Philip |
February 26, 2020, 12:34 |
#512 | |
Torsten Schenkel
Rep Power: 12 |
EDIT: Quick time step estimate: SOS = sqrt(E/rho) = sqrt(5.6e-6 Pa / 1000 kg/m^3) = 75 m/s for Co = 1: deltat = deltax/V = 0.0033m/75m/s = 4.4e-5s so we are close with the 1e-4s. Will try 2e-5 and see if that gives close to zero damping. |
February 27, 2020, 06:41 |
#513 | |
Torsten Schenkel
Rep Power: 12 |
There is still a fair amount of damping for a time step of 2e-5 s. Co<1.png A lot less than for 1e-3 or 1e-4, but still there. |
February 27, 2020, 06:47 |
#514 |
Philip Cardiff
Rep Power: 34 |
Hi Torsten,
The damping error should reduce based on the order of accuracy of the time discretisation: for 1st order Euler, halving the time step will half the error; for 2nd order schemes, halving the time step will reduce the error by a factor of 4. See the attached image comparing different time schemes for an oscillating beam using a cell-centre finite volume approach (from this thesis). Philip |
March 2, 2020, 03:48 |
#515 |
Sita Drost
Rep Power: 18 |
Hi everyone,
Good, it looks like I'm slowly getting there with my Hron-Turek FSI 1 case with gravity. Delaying the onset of coupling to 0.01 s seemed to help (can't delay it too much though, as around t = 0.24 s the flexible plate would fall out of my domain). Still, the simulation crashes after just over 0.7 s, and the results start looking funny after some 0.3 s. The tip displacement starts oscillating, as can be seen in the attached plot. Also, at t = 0.4 s waves appear in the plate shape, and the fluid mesh deformation doesn't seem to keep up with the solid mesh deformation (see attached screenshots, one is coloured by p (fluid) and sigma_eq (solid)). With increasing time, the plate shape returns to something looking more physically realistic, and the fluid and solid mesh deformations seem to catch up. But just when I thought things might be getting back to normal and stable, both the interface displacement and the velocity magnitude blow up and the simulation crashes. This looks like I should be paying more attention to my simulation settings. Is there anything in particular that I should be changing to get stable, physically realistic results? Many thanks, Sita P.S. Adding relaxation only seems to make things worse (both FSI relaxation and D/DD relaxation) Last edited by sita; March 3, 2020 at 05:35. |
March 3, 2020, 11:01 |
#516 |
Sita Drost
Rep Power: 18 |
Brief update: with RBFMeshMotionSolver, the simulation crashes even more spectacularly, at t = 0.402 s this time (see attached screenshot).
I'm getting a bit desperate, why is this case so much harder in solids4Foam than in fsiFoam (foam-extend-3.1)? Any tips anyone? Thanks! Sita |
March 3, 2020, 11:53 |
#517 |
Philip Cardiff
Rep Power: 34 |
Hi Sita,
Can you attach a simple example case to reproduce the problem? Philip |
March 4, 2020, 05:31 |
#518 |
Sita Drost
Rep Power: 18 |
Hi Philip,
Sure, here you go. I haven't changed an awful lot since last time I uploaded it (post #496), but clearly the changes that I did make worked out rather disastrously. Some additional notes: - With a lower gravity value the case runs just fine - With a linear elastic material model the case is stable as well, but as then I had to use linear deformation too, the tip displacement in x-direction was negligible, which clearly is not physically correct here. Thanks in advance for having a look, Sita |
March 4, 2020, 11:44 |
#519 | |
Daniel
Rep Power: 21 |
I have looked through the attached case and made three minor changes: 1- file: fsiProperties:
Regards, D. Khazaei |
March 4, 2020, 14:34 |
#520 |
Sita Drost
Rep Power: 18 |
Hi Daniel,
Thanks a lot for your suggestions! I initially set coupled to yes, and disabled couplingStartTime, just like you did now, but I didn't yet try playing with this transition period of the inlet velocity. With the transition period kept at 0, even the case without gravity (i.e. the original Hron-Turek FSI 1 benchmark) wouldn't run, so I'm definitely going to try playing with this transition period. Cheers, Sita |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 15:22 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 17:01 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
