Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend"
Like Tree134Likes
Closed Thread
Old   February 7, 2020, 06:45
Default RBF(Mesh)MotionSolver in solids4foam
  #481
Sita Drost
sita is on a distinguished road
Hi Jon,
Just wondering: did you ever get RBFMeshMotionSolver to work with fsiFoam? I'm trying to use it with solids4foam (foam-extend-4.1, Ubuntu 18.04), and got the same error message you got (Problem with fluid mesh motion solver selection), both for RBFMeshMotionSolver and RBFMotionSolver.
I came across a presentation by Željko Tuković, in which he uses RBFMeshMotionSolver with solids4foam, even combined with overset grid, so apparently it's possible to get it working, but it clearly doesn't work straight out of the box.
Did you find a solution?
Many thanks,
Sita
Originally Posted by jcappola View Post
Hi All,
I'm using the foam-extend 4.0 bazaar to do FSI on flexible airfoils and I am having some trouble with mesh motion. It seems that the fsiFoam solver has only been implemented with RBF point interpolation and while RBFMeshMotionSolver is in the library, fsiFoam refuses to use it when I patch it into the dynamicMeshDict.
After the first time step's solid predictor I get the following error when the cell motion step occurs:
--> FOAM FATAL ERROR:
    From function fluidSolidInterface::moveFluidMesh()
    in file fluidSolidInterface/fluidSolidInterface.C at line 1922.
FOAM aborting
I am wondering if someone has been able to patch in the RBFMeshMotionSolver for fsiFoam and could give some hints on how to move forward as the .moveFluidMesh() call only allows for fe/fv motionSolvers to be used and is hard coded.
Thanks,
Jon
sita is offline
Old   February 7, 2020, 18:04
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
See commit bc08236 to the development branch of solids4foam: I added the following code to fluidSolidInterface.C:
        // Check for RBF motion solver
        const bool rbfMotionSolver =
            isA<RBFMeshMotionSolver>
                fluidMesh().lookupObject<motionSolver>("dynamicMeshDict")
	// Set motion on FSI interface
        if (feMotionSolver)
        else if (rbfMotionSolver)
            // Prepare list of patch motions
            Field<vectorField> motion(fluidMesh().boundaryMesh().size());
            // Initialise all fields to zero
            forAll(fluidMesh().boundaryMesh(), patchI)
                motion[patchI] = vectorField
                    fluidMesh().boundaryMesh()[patchI].size(), vector::zero
     	    // Loop through all FSI interfaces
            forAll(fluid().globalPatches(), interfaceI)
		// Interpolate the FSI interface point motion to the faces
		const vectorField interfacePatchMotion =
		    fluidPatchesPointsDispls[interfaceI]
                  - fluidPatchesPointsDisplsPrev[interfaceI];
                // Create interpolator
                primitivePatchInterpolation interp
                    fluidMesh().boundaryMesh()[fluidPatchIndices()[interfaceI]]
                // Set motion of FSI interface
                motion[fluidPatchIndices()[interfaceI]] =
                    interp.pointToFaceInterpolate(interfacePatchMotion);
            // Set motion field in RBF motion solver
            // Note: take displacement as opposed to velocity
            const_cast<RBFMeshMotionSolver&>
                fluidMesh().lookupObject<RBFMeshMotionSolver>("dynamicMeshDict")
            ).setMotion(motion);
        else
Then constant/fluid/dynamicMeshDict can be set as (for example):
dynamicFvMesh dynamicMotionSolverFvMesh;
solver RBFMeshMotionSolver;
diffusivity quadratic inverseDistance (interface);
// Settings for the RBF solver
staticPatches    (top bottom left);
movingPatches    (interface);
fixedPatches     (inlet outlet);
interpolation
    function     TPS;
coarsening
    enabled      no;
I haven't looked into the "best" settings but the beamInCrossFlow/linearGeometryElasticBeam tutorial runs in serial with these settings. I am not sure what the difference between fixed and static patches are. Parallel does not seem to work yet, so I will have to dig further to find out why (feel free to!).
Philip
Daniel_Khazaei likes this.
bigphil is offline
Old   February 9, 2020, 03:35
Sita Drost
Hi Philip,
Perfect, I'll have a look a that, thanks!
Sita
sita is offline
Old   February 10, 2020, 07:16
Sita Drost
Hi Philip,
Sorry, just a quick question: can I build this development branch version next to the version that I already built from the master branch, or should I replace everything? Or would adding the code you mentioned to my master branch version, and re-building, work as well (i.e. without messing up my git clone)?
Many thanks,
Sita
sita is offline
Old   February 10, 2020, 07:28
bigphil's Avatar
Philip Cardiff
Hi Sita,
There are at least three ways you can do this:
  1. Use "git checkout development" to change to the development branch, and you can then use "git checkout master" to change back
  2. Create a second clone of the entire repo and change this repo to the development branch
  3. Copy the code segment into the relevant file in the master branch
All three of these are fine. Personally, I prefer option 1.
Once I have checked all tutorial still run I will merge the change into the master branch anyway.
Philip
bigphil is offline
Old   February 10, 2020, 08:01
Sita Drost
Hi Philip,
Thanks a lot for your quick reply, I'll go for the first option so.
Sita
sita is offline
Old   February 10, 2020, 08:06
bigphil's Avatar
Philip Cardiff
Originally Posted by sita View Post
Hi Philip,
Sita
No problem. By the way, after changing branch, you can run "git pull" to pull the latest changes from that branch ("git pull" may update all branches if your git settings are configured using the old approach).
bigphil is offline
Old   February 10, 2020, 09:52
Sita Drost
Hi Philip,
Great, that worked, the error "Problem with fluid mesh motion solver selection" is gone now. Unfortunately a new error popped up:
Time = 0.001, iteration: 1
Modes before clean-up (plate): 0, modes after clean-up (plate): 0
Current fsi under-relaxation factor (plate): 0.05
Maximal accumulated displacement of interface 0: 2.40967e-05
solids4Foam: fluidModels/finiteVolume/RBFMeshMotionSolver/RBFMeshMotionSolver.C:662: virtual void Fo
am::RBFMeshMotionSolver::solve(): Assertion `index == nbGlobalStaticFaceCenters[Pstream::myProcNo()]
' failed.
Aborted (core dumped)
Does this look familiar to you?
I'll try to run this beamInCrossFlow/linearGeometryElasticBeam tutorial first, see if I can work out how things work from there.
Thanks,
Sita
EDIT: Woops, the beamInCrossFlow/linearGeometryElasticBeam tutorial gives me the exact same error...
EDIT 2: Strange, the line of code that failed (the one with Pstream::myProcNo() ) should only be used in a parallel case (if ( Pstream::nProcs() > 1 ) ). I'm fairly sure I'm running the case in serial mode, as I haven't decomposed anything etc.
sita is offline
Old   February 10, 2020, 10:36
bigphil's Avatar
Philip Cardiff
Hi Sita,
Are you running the case in serial or in parallel?
As noted in my previous post, parallel is currently not working: there is something wrong in the RBFMeshMotionSolver.
Philip
EDIT: I have checked the linearGeometryElasticBeam case in parallel on my Ubuntu box and it does work. I have realised there is a problem with openmpi on my mac (unrelated to solids4foam).
Can you try clean and re-compile solids4foam (run "wclean lib && wmake libso" in src/solids4FoamModels)? And update to development commit 699223c first, where I included some example RBF settings. You need to enable the RBF motion in linearGeometryElasticBeam tutorial by changing the following lines in the fluid/dynamicMeshDict:
solver velocityLaplacian;
//solver RBFMeshMotionSolver;
to
//solver velocityLaplacian;
Last edited by bigphil; February 10, 2020 at 11:50. Reason: See comments at the end of the post above
bigphil is offline
Old   February 10, 2020, 15:17
Sita Drost
Hi Phil,
That's the thing, I actually am running the case in serial (on Ubuntu 18.04, with foam-extend-4.1), so I was really surprised that I got an error related to this "if nProc > 1" block. I already changed the dynamicMeshDict like you suggested in post #483, I'll try the cleaning and re-compiling too, tomorrow. Thanks for your help so far!
Sita
sita is offline
Old   February 11, 2020, 06:46
Sita Drost
Hi Philip,
I just tried cleaning and re-compiling solids4foam, after updating to commit 699223, but I'm still getting the same error. As you wrote that for you the tutorial case now also works in parallel on Ubuntu, I'm starting to think that something might be wrong with my foam-extend-4.1 install (I had a good deal of trouble installing that, see also here (last page), and I'm still not sure whether everything's working as it should now).
For now I'll try installing the pre-built binary of foam-extend-4.1, see if that helps. I read that the pre-built binary has some trouble with parallel cases in combination with the GAMG solver, but in fairness I'd be happy enough with just serial runs by now.
Thanks,
Sita
EDIT: Too bad, with the foam-extend-4.1 pre-built binary it doesn't work either, still the same error...
EDIT 2: Ah wait, sorry, the error isn't in this if-block; I missed a closing parenthesis. Still, can't figure out why exactly it failed; it seems the index in this for-loop (lines 653-660) doesn't reach nbGlobalStaticFaceCenters
EDIT 3: Hm, commenting out those assert commands "solves" my problems for now. The results of the beamInCrossFlow/linearGeometryElasticBeam tutorial look alright, but this is not a permanent solution of course...
sita is offline
Old   February 13, 2020, 05:14
Sita Drost
Hi everyone,
I've two quick questions about solids4foam/RBFMeshMotion (foam-extend-4.1, Ubuntu 18.04.3):
1. Does anyone know how I'm supposed to add gravity to a solids4foam computation with RBFMeshMotion? There's a dictionary g in constant/solid, which works fine with other mesh motion solvers, such as velocityLaplacian, but when I use RBFMeshMotion, gravity seems to be ignored.
Looking through the solver log file, I noticed:
g field not found in constant directory: initialising to zero
but that line is also there when I use velocityLaplacian, and in that case gravity is picked up alright. Just to be sure I copied g into constant, but that didn't have any noticeable effect.
2. Whenever I'm postprocessing solids4foam results in ParaView, it's complaining about duplicated entries:
ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 7484
vtkOpenFOAMReaderPrivate (0x555867625480): Error reading line 490 of /home/openfoam/foam/openfoam-4.1/tutorials/solids4foam/fluidSolidInteraction/beamInCrossFlow/overset/elasticBeam/4/solid/D_0_0: Found duplicated entries with keyword value
I'm using a system installed ParaView 5.4, because I didn't manage to get the Third Party version installed. As also the PVFoamReader wouldn't build somehow, I'm using paraFoam -builtin (or just "touch case.foam && paraview case.foam"). Could that be causing these errors?
Thanks in advance,
Sita
sita is offline
Old   February 13, 2020, 08:19
bigphil's Avatar
Philip Cardiff
Hi Philip,
Thanks,
Sita
Glad to made progress.
One other point to mention: I checked this case only with foam-extend-4.0; I did not check foam-extend-4.1. Maybe this may be the reason for the different behaviour. I can check with fe41 too.
Philip
bigphil is offline
Old   February 13, 2020, 08:25
bigphil's Avatar
Philip Cardiff
Hi everyone,
Some of the solidModel implementations may not include gravity (most do but some may not) so you may need to check for the one you are using. The choice of fluid mesh motion solver "should" not affect solid in any way.
Feel free to upload a small test case here demonstrating the problem.
Thanks in advance,
Sita
I also use the ParaView binaries from the ParaView website. This warning can be ignored but I have not looked into what is causing it.
bigphil is offline
Old   February 17, 2020, 05:03
Sita Drost
Hi Philip,
Thanks for getting back, sorry for the delay on my side. About the RBFMeshMotionSolver: I took another look at the results, and it looks like gravity is indeed included, but the fluid and the solid seem to be decoupled.
I was messing around with the HronTurek tutorial as a testcase, changed the parameters to get the FSI1 case, and later on added gravity. When I use the velocityLaplacian solver, the results look alright (see attached plot, uA.png), but when I change to RBFMeshMotion, the solid seems to be deforming without affecting the flow (see attached image, RBF_seems_decoupled.png, and plot, uA_RBF.png). I'm also attaching my testcase, so if you have time you can take a look. I don't know, it's probably something really silly that I'm missing here, but I haven't found it yet.
And about the ParaView warnings/errors: in my case the variables that cause those errors aren't loaded, I only get pointD0 etc. Is there a way to load these variables anyway?
Many thanks,
Sita
sita is offline
Old   February 17, 2020, 05:09
Mikko
Flowkersma is on a distinguished road
Hi Sita,
Can you try removing the "frontAndBackPlanes" patch from the dynamicMeshDict/staticPatches dictionary?
Best, Mikko
bigphil and Daniel_Khazaei like this.
Flowkersma is offline
Old   February 17, 2020, 06:21
Sita Drost
Hi Mikko,
Sure, I can give that a try. Do you want me to remove it altogether, or to move it to e.g. fixedPatches? Do you happen to know the difference between staticPatches and fixedPatches, by the way? Is there a reason that removing frontAndBackPlanes from staticPatches should fix the fluid-solid coupling?
I'll let you know how I get on,
Sita
EDIT: Cool, that actually seems to work! Thanks for the tip, can you explain it?
sita is offline
Old   February 17, 2020, 09:28
Mikko
Hi Sita,
To be honest, I do not know what is the difference between a static and a fixed patch. If a patch is either fixed or static then the nodes/cellCenters on that patch are not moving and therefore you were not getting any deformations for the 2D case. If you look at the example dynamicMeshDictionaries by the authors of the mesh deformation library, they seem to be also using both static and fixed patches for the 2D cases:
cylinderFlap_FSI3
beamInCrossFlow2D
Best, Mikko
Old   February 17, 2020, 10:12
Sita Drost
Hi Mikko,
Yeah, I noticed those tutorials, couldn't figure out the difference either though. I still don't quite get how my flexible plate was able to bend straight through the lower wall of my domain, but I'm glad everything is working as it should now.
Thanks again,
Sita
sita is offline
Old   February 19, 2020, 03:47
Sita Drost
Hi everyone,
I seem to be running into the same issue as Mike in post #436: as the deformation in my toy case (HronTurek FSI1 with gravity) is too large to be considered linear, I switched the solidModel in solidProperties from linearGeometryTotalDisplacement to unsNonLinearGeometryTotalLagrangian. This model wouldn't combine with the linearElastic material type in mechanicalProperties (as is indicated in Philip Cardiff's solids4foam training slides, but I tried anyway...), so I switched that to neoHookeanElastic.
And so now I'm getting these warnings
--> FOAM Warning :
    From function void Foam::neoHookeanElastic::correct(surfaceSymmTensorField& sigma)
    in file materialModels/mechanicalModel/mechanicalLaws/nonLinearGeometryLaws/neoHookeanElastic/neoHookeanElastic.C at line 401
     Material linearity enforced for stability!
indicating that the solver is struggling to converge. And indeed a little while later the simulation crashes. As Philip suggested, I tried under-relaxation of D (and Deqn, and DD, and DDeqn) in system/solid/fvSolution, but so far the warnings keep coming up, and the simulation keeps crashing. Does anyone have any tips to improve things?
Many thanks,
Sita
sita is offline
Closed Thread
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
