Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend"
Like Tree134Likes
Closed Thread
Old   May 17, 2015, 16:52
Svensen is on a distinguished road
I'm trying to make FSI simulation of elastic pipe. icoFsiElasticNonLinULSolidFoam is used for this. When I use default values for material my simulation works OK. But when I try to change them to actual (increase fluid density from 1 to 1141), my simulation crashes on second FSI iteration with
--> FOAM FATAL ERROR:
zero and complex eigenvalues in tensor: (1.67727e+31 -3.07921e+31 -1.86008e+29 -2.51065e+31 4.60916e+31 2.78429e+29 -4.70076e+31 -3.74209e+31 6.17348e+31)
From function eigenValues(const tensor&)
in file primitives/Tensor/tensor/tensor.C at line 129.
The test case and log file are here: https://yadi.sk/d/OAfhaP7egdTHG
Can some one help me ? Thanks.
Svensen is offline
Old   May 19, 2015, 10:03
Stephanie
stephie is on a distinguished road
Hello Svensen,
I also have the same problem. I use the icoFsiElasticNonLinULFoam Solver to run the HronTurekFsi Case. Unfortunately I allways get this mistake.
Did you find a solution?
I would be very grateful for anyone's help,
thank you and best regards,
Stephie
stephie is offline
Old   May 21, 2015, 14:19
I can only guess where the problem exists. As you know, in all classical OpenFOAM cases you never write the fluid density value. Here (in FSI cases) we need to define it explicitly. I've searched the code of icoFsiElastic...Foam solver and find only one line where this density value is used. It is used for calculation of the force action by fluid on the solid and formula looks like nu*rho. All looks fine, but in the HronTurek case you can see that the nu value is 1e-3 and rho is only 1 (ONE !!) it's very low ! So, using the formula we have 1e-3 *1 = 1e-3. But when I put my actual data into the fluid parameters, using this formula (nu*rho) I've got something like 6.5e-3. I only can guess that this value is to big for this solver or the discretization schemes which it used by default. So it's become unstable and crashes.
It's only the suggestion...
If you will find the solution please let me know ! I need it very very much !!
Svensen is offline
Old   May 22, 2015, 06:09
Stephanie
Hey, yes you might be right. I am running the case with a density of 1000 (water) which is really high in comparison.
Today I tried the hint of Philip Cardiff some posts before (#209).
I changed in the rotateSolidFields.H
rho = rho/J into //rho = rho/J
My case run around 0.476 s, after it become struggeling and stops, because of floating point except.
Time = 0.476, iteration: 34
Current fsi under-relaxation factor (Aitken): 3.47732e-08
Maximal accumulated displacement of interface points: 0.00970624
DILUPBiCG: Solving for Ux, Initial residual = 0.00112037, Final residual = 2.90452e-07, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 0.0060397, Final residual = 4.07335e-07, No Iterations 4
GAMG: Solving for p, Initial residual = 0.490316, Final residual = 0.00244083, No Iterations 6
time step continuity errors : sum local = 1.51006e-06, global = 5.84117e-09, cumulative = -0.000922631
Moving mesh time step continuity errors : sum local = 1.51006e-06, global = 5.84117e-09, cumulative = -0.000922625
Setting traction on solid patch
Total traction force = (-18.9099 -18.0944 3.34335e-17)
Solving for DU, Initial residual = 0.0130961, Final residual = 9.65723e-07, No outer iterations 142
Current fsi residual norm: 0.172987
Time = 0.476, iteration: 35
Current fsi under-relaxation factor (Aitken): 1.73919e-08
DILUPBiCG: Solving for Ux, Initial residual = 0.00119781, Final residual = 4.88617e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.0070903, Final residual = 1.57914e-07, No Iterations 5
Floating point exception
If I irgnore this error, the case stops again, but again because of "Floating point exception". The last time this was the point where I got the error of complex eigenvalues. I am not sure if it helps to comment this line out for stopping the mistake of complex eigenvalues or if it is luck.
I will further searching.. maybe there will be a better solution and the case will run.
Did you try HronTurekFsi3 from extend-bazaar? It is amazing. It run really fast and it has already a density of 1000 included. Maybe this might be an other possibility for you.
stephie is offline
Old   May 24, 2015, 14:26
"Did you try HronTurekFsi3 from extend-bazaar? It is amazing. It run really fast and it has already a density of 1000 included. Maybe this might be an other possibility for you"
I've tried it today. Yes it is very fast, but when I've applyied my geometry and parameters to the test case there were no coupling. The solid domain didn't deformed... but in the old HronTurek case it works ! Very strange...
Svensen is offline
Old   May 26, 2015, 15:31
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Yep, the new FSI framework (currently located in foam-extend-3.1/extend-bazaar) supersedes the icoFsiElasticNonLinULSolidFoam solver.
Željko presented this framework at the OpenFOAM Workshop 2014 in Zagreb: abstract and slides.
The major improvement with regard to FSI coupling is the implementation of the IQN-ILS algorithm: this seems much better than Aitken's/fixed under-relaxation.
Also, the plugin approach used for the solid and fluid solvers should allow easier extension to other fluid/solid models e.g. multi-phase, compressible, plasticity, etc.
Best,
Philip
bigphil is offline
Old   May 27, 2015, 11:57
Did you find some way of how to solve this issue ? Because I had a similar problems. Today I've run my simulation with icoFsiElastic...Foam it runs sometime, all was OK, Courant is <1, but the suddenly it crashes with eigenvalues problem...
I think that we are working in the similar field, so we have the same issues with simulation..
Svensen is offline
Old   May 28, 2015, 04:51
Stephanie
Hey,
first, thank you Philip for the links to tha abstract and the slides
I am sorry, but I didn't find a solution up to now. At the moment I try to figure out where the problem might be. The last days I tried to run the new solver of my tutor with the old HronTurek case. But it allways crashes after around 0.4 seconds. Yesterday, I turnd off the FSI to see if the fluid or the solid part might be the problem. With out coupling the case run, I can see the current. Than I tried to use the density and Emodul which is given be the case (density of 1 kg/mł and E=1.4e6) and the case is still running ( at the moment 2.6sec). At home I startet the normal case with the icoFsiElsaticNon... and an adjusted density of 1000kg/mł. After 5 seconds the case stops because of complex eigenvalues.
I am not sure if it works to commend "rho = rho/J" out..there is allways the same mistake with floating point and complex eigenvalues. I think the density might be the problem, but I don't know how to solve it...
It would be wonderful if anyone had a solution. I really would like to use the old version to test the new solver of my tutor..it is the same structure.
stephie is offline
Old   May 28, 2015, 08:03
Ireneusz Czajka
iczajka is on a distinguished road
Some months ago I had similar problems with FSI calculation. But it was related to mesh displacement. Mesh quality became very poor and floating point exeption was raised.
Better mesh, and my problem disapeared.
iczajka is offline
Old   May 28, 2015, 11:51
bigphil's Avatar
Philip Cardiff
Hey,
Hi Stephie,
Does the new solver work for you with the new cases?
The Hron-Turek-FSI-2 and Hron-Turek-FSI-3 are both provided as tutorials and should just work.
If your current case has convergence problems, I would closely compare the settings in the new tutorial cases to check if you have appropriate settings.
There are some small but important changes in the new code, for example, in the Hron-Turek cases a function object is used to enable FSI coupling once the flow has developed; this overcomes problems at the start with the flag bouncing around before the flow has developed.
Philip
bigphil is offline
Old   June 2, 2015, 04:36
Stephanie
Hello Philip,
I couldn't use our new solver for the new case up to now. Unfortunately there are some differences with some terms. Maybe we will find a way and change this, so that we could run the solver with HronTurekFSI3.
While the last days I run HronTurekFSI2 with our solver with a density of 1 für the fluid and a density of 10 for the solid, and an Emodule of 1,4e6. And it works...the simulation ist still running.
I don't understand where the problem might be, when I increase the density of the fluid to 1000 and the solid to 10000. The case interrupts allways at 0.476s iteration 35. I tried many things, but it allways stops at this one point.
I also tried to turn off the coupling and start with developping the fluid and later join the coupling, but it also didn't work. The fluid part runs without any problems. But together withe the solid part it allways stops.
best regards,
Stephie
stephie is offline
Old   June 2, 2015, 07:07
Damon Lee
D_LEE is on a distinguished road
Hello everyone,
I am also enjoying the new FSI library, but I would like to run the FSI solvers from a different start point (like stopping the solver and then starting it up again), and I don't think that functionality is implemented.
If I run the HronTureckFsi3 tutorial (in controlDict I set the startFrom to latestTime) for a few recorded timesteps and then stop it, I can't resume it with fsiFoam, the error that comes up is:
--> FOAM FATAL IO ERROR:
cannot open file
…../run/FluidStructureInteraction/run/fsiFoam/HronTurekFsi3_1/fluid/0.26/solid/V0 at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
The same thing happens if I run it with weakFsiFoam. I don't understand that error because if I grep -r V0 . to the whole folder nothing useful comes up yet in the time directories the fluid does have a V0 as volScalarField:imensionedInternalField, and the solid does not.
Also, when I try and do this in parallel I get this kind of error:
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] local to global face zone point map is not correct
[2]
[2]     From function flowModel::calcGlobalToLocalFaceZonePointMap()
[2]     in file flowModels/flowModel/flowModel.C at line 244.
[2]
FOAM parallel run aborting
[2]
My questions are this:
Is such functionality going to be in the FSI library when it gets included in foam-extend?
Is it possible to do this with this FSI library in parallel as well as serial?
How would I go about editing the library to make it run from the latestTime?
Any help at all is appreciated.
D_LEE is offline
Old   June 2, 2015, 12:14
bigphil's Avatar
Philip Cardiff
Hello Philip,
best regards,
Stephie
Stephie,
Yep, having comparable fluid and solid densities is a difficult FSI problem;
using a small fixed under-relaxation factor or the new IQN-ILS procedure should help to overcome the convergence problems.
Philip
bigphil is offline
Old   June 2, 2015, 12:17
bigphil's Avatar
Philip Cardiff
Originally Posted by D_LEE View Post
Hello everyone,
cannot open file
FOAM exiting
[2]
[2]
[2]
[2]
[2]
In theory it should not be a problem to restart, we just have to make sure all the relevant fields are written out (something seems to want to old cell volumes V0, and also the golbalFaceZone field in parallel).
I will let you know if I get time to look at it.
In short to answer your questions, yep it would be intended to include such functionality.
Philip
D_LEE likes this.
bigphil is offline
Old   June 9, 2015, 04:32
Stephie, I've found the way how to make FSI simulations stable, but I'm not sure that this way is totally correct. I've tried to analyse the log and I've found that at some value of interface displacement my simulations crashes. After searching the source code I've found the following patter:
Info << "Maximal accumulated displacement of interface points: " << delta << endl;
if(delta < interfaceDeformationLimit) {
// Move only interface points ...
else {
// Move whole fluid mesh ...
When I changed the interfaceDeformationLimit value in the settings file, I've got a stable solution.
But the problem is: at the beginning of simulation my elastic pipe deforms very well, but after some period of time the amplitude becomes slower and slower.. and have a value about 1*10^-9 m. I don't know is it a result of my trick or not, but it looks unrealistic for my case. Maybe you will try to make the same thing (increase value interfaceDeformationLimit to 10^6) and run your simulation. I think that together we can solve this problem (with FSI convergence and stability) much faster. Maybe Philipp Cardiff also will give some help to us...
Svensen is offline
Old   June 10, 2015, 10:08
Stephanie
Hey Svensen,
today I tested your proposal -interfaceDeformationLimit 1e6 and the computation stops after 0.288 because of floating point exception..the displacement goes up to over 150
First I did a mistake and wrote 10e6..the simulation chrashes after 0.288 with a displacement of around 170....
I also tried to changed the number just a litte bit, I took 0.1, but it also stops after 0.216 seconds because of complexe eigenvalues.
I am not sure if it is a goog idea to change this value.. the results seem to be unrealistic.
I also tried the hint of Philip and changed the fixed under-relaxation factor and used the new IQN-ILS procedur.. but I didn't get better results.
I will try further.. we will hopefully find a solution.
stephie is offline
Old   August 21, 2015, 18:16
ok
Maimouna is on a distinguished road
Dear Cardiff and others,
HronTurekFsi3 in extend-bazaar was working fine, and then I tried to implement the similar case given in http://www.sciencedirect.com/science/article/pii/S0045782505005177 p. 5768 but unfortunately it gives me error I think that error belongs to blockMeshDict file. I went through that case many times but I couldn't notice the error. If any one could go through my attached case and let me know what is the problem, I will be really appreciated.
Lots of thanks in advanced.
Maimouna
Maimouna is offline
Old   September 1, 2015, 05:19
Vasilis Papadimitriou
Needled is on a distinguished road
Hey guys,
Since I have been working on my master thesis with fsiFoam these past few months and since I had lots of problems that other people in these thread had that remain unanswered up at this point, I thought I would shed some light on these that I managed to solve (or temporarily bypass) and throw out a new issue I have encountered hoping that someone may shed some light. Also I want to thank the developers of this package and the continued support for the software and the community.
First, to address the globalFaceZones issue during decomposition, there is a simple explanation. After some searching through the source code I realized that there exists a different utility called decomposeParFsi compiled along with the rest of the FluidStructureInteraction package of the extend-bazaar. This works like a charm for decomposing a parallel case, just make sure to setup the face zones of the interface between the 2 meshes properly. Took some search to find, maybe there should be some documentation included along with the solver in some of the tutorials for parallel decomposition, in my opinion at least (maybe an Allrun script for parallel? Shouldn't be that hard to make!)
Also, for the restarting issue, I found that the problem lies with the backward d2dt2 scheme for the solid, when the solver can't find the old cell volume file for the solid, it should automatically switch to an Euler scheme (normally) but it doesn't. I haven't messed with the code to fix this, but I found a simple solution to bypass this. You simply need to delete the uniform folder, along with all the "old" values files (like D_0, D_0_0, V0 for the fluid mesh, U_0 and so on) for the time you want to restart from along with using an Euler d2dt2 scheme for the solid mesh and you should be fine restarting your case.
Now for a new issue I haven't seen addressed by anyone else yet. I have been trying to use the updated Lagrangian stress model for my simulation since I am working on an HPC model and resources are not really an issue (while simulation time is). I take it that the unsIncrTotalLagrangian stress model implemented along with the solver is the equivalent to an updated Lagrangian stress model from the old icoFsi...SolidFoam solver from the solid Mechanics branch of foam-extend-3.1. I seem to get a segmentation fault as soon as I reach the point in the simulation that the stress modelling happens and I haven't been able to figure out why this happens when I use the unsIncrTotalLagrangian model, while the simple unsTotalLagrangian works just fine. Also I tried using similar settings with my simulation in one of the tutorial cases (the 3dTube) and the unsIncrTotalLagrangian stress model and it seems to run perfectly. I have also enable the built-in debug flag in the stressProperties file, it doesn't print anything out so I guess it doesn't get very far before it crashes.
Here is the log file from before my case crashes:
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
 Reading stress mesh
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model oneEqEddy
oneEqEddyCoeffs
    ce              1.048;
    ck              0.094;
Creating traction displacement incr boundary conditions
Creating fixed displacement boundary condition
Selecting rheology model linearElastic
Creating constitutive model
Selecting coupling scheme IQN-ILS
Starting time loop
Creating pointHistory function object.
History point ID: 40086
History point coordinates: (-0.0023936 -0.00239322 -9.44141e-07)
Reference point coordinates: (0 0 0)
Time = 2e-05
Create extended GGI zone-to-zone interpolator
Checking fluid-to-solid face interpolator
Fluid-to-solid face interpolation error: 0.000590438
Checking solid-to-fluid point interpolator (GGI)
Extended GGI, master point distance, max: 1.04692e-07, avg: -1.6307e-07, min: -0.000599455
Extended GGI, master point orientation (<0), max: 0.999992, min: -1, nIncorrectPoints: 10/34288
Solid-to-fluid point interpolation error (GGI): 0.000599455
Number of uncovered master faces: 0
Number of uncovered slave faces: 0
Time = 2e-05, iteration: 1
Modes before clean-up : 0, modes after clean-up : 0
Current fsi under-relaxation factor: 0.05
Creating accumulated fluid interface displacement
GAMG:  Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1
GAMG:  Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1
GAMG:  Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1
Evolving flow model
Courant Number mean: 0.0291375 max: 0.792268 velocity magnitude: 19.636
smoothSolver:  Solving for Ux, Initial residual = 0.0356957, Final residual = 5.89936e-06, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.0322748, Final residual = 5.32878e-06, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.00358901, Final residual = 1.6217e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.902127, Final residual = 0.0622434, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.145781, Final residual = 0.0115296, No Iterations 6
time step continuity errors : sum local = 6.81989e-05, global = 4.35455e-07
GAMG:  Solving for p, Initial residual = 0.0242339, Final residual = 0.0021307, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.00277903, Final residual = 7.85409e-07, No Iterations 12
time step continuity errors : sum local = 2.40709e-08, global = -2.87158e-10
smoothSolver:  Solving for k, Initial residual = 0.0100646, Final residual = 6.72539e-06, No Iterations 3
bounding k, min: 0 max: 22.0972 average: 0.796823
Total force (fluid) = (-4.78269 -7.25492 24.9006)
Total force (solid) = (10.3924 11.2104 -45.6975)
Evolving stress model unsIncrTotalLagrangianStress
Time: 2e-05, outer iteration: 0
Application 2547001 exit codes: 139: Segmentation Fault.
If anyone has encountered a similar problem and can shed some light for me please let me know. Also please let me know if you want me to provide some additional information about my setup if you think it's needed to identify the cause of this issue.
Best regards,
Vasilis
bigphil and D_LEE like this.
Needled is offline
Old   September 7, 2015, 11:16
Default Seeking literature for large strain solid dynamics in OpenFOAM
  #319
Jibran
Jibran is on a distinguished road
Dear All,
I am currently in the process of publishing my research on large strain solid dynamics implemented in OpenFOAM. The method we employ (visit my website for more details) is based on a mixed formulation which eliminates the shortcomings posed by the conventional displacement based formulations.
As part of the literature review, I am looking for literature (journal publications only) that anyone of you has published regarding large strain solid dynamics in OpenFOAM. After a quick search, I only found one article detailed as follows:
@Article{cardiff2014,
Title = {A large strain finite volume method for orthotropic bodies with general material orientations},
Author = {Cardiff, Philip and Kara{\v{c}}, A and Ivankovi{\'c}, A},
Journal = {Computer Methods in Applied Mechanics and Engineering},
Year = {2014},
Pages = {318--335},
Volume = {268},
Publisher = {Elsevier},
I would be pleased to know if there are more articles already published or in the process of publication on this topic. Thanks.
Jibran Haider
Jibran is offline
Old   September 7, 2015, 11:35
bigphil's Avatar
Philip Cardiff
Originally Posted by Jibran View Post
Dear All,
Year = {2014},
Pages = {318--335},
Volume = {268},
Hi Jibran,
I had a look at the presentation on your website, your approach looks very interesting. I would be very interested in seeing more details on your discretisation and solution methodology.
By "mixed", do you mean that your primary variables are displacement/velocity and pressure?
As regards publication of large strain solid dynamics in OpenFOAM, I am not aware of another journal paper but there are a few conference papers, such as:
Best regards,
Philip
bigphil is offline
Closed Thread
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
