February 4, 2012, 16:27 |
Bug in rhoReactingFoam
Francesco Capuano
Rep Power: 16 |
Hi everybody,
I was running the counterFlowFlame2d tutorial with both reactingFoam and rhoReactingFoam to check the differences between the two solvers in terms of results and performances. However, the rhoReactingFoam solver was apparently not solving for transport of species. I have checked the YEqn.H file and indeed, after defining the Yi equation, the two lines YiEqn.relax(); YiEqn.solve(mesh.solver("Yi")); are completely missing! |
February 6, 2012, 05:22 |
Francesco Capuano
Rep Power: 16 |
I forgot to specify: the bug above-mentioned refers to OpenFOAM v. 2.1.0. In versions 2.0.1 and older the routine is correct as the Yi equation is directly solved by the solve() command.
reactingFoam vs rhoReactingFoam | Scot | OpenFOAM Running, Solving & CFD | 8 | June 2, 2016 12:28 |
Problem/ bug in mesh.cellCells() ?? | daZigeiner | OpenFOAM Bugs | 2 | May 18, 2015 16:54 |
Serious bug in LES interface | fs82 | OpenFOAM Bugs | 21 | November 16, 2009 09:15 |
Bug reports | Mattijs Janssens (Mattijs) | OpenFOAM | 0 | January 10, 2005 11:05 |
Forum y2k Bug | Jonas Larsson | Main CFD Forum | 1 | January 5, 2000 11:22 |
