Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Strange rhoCentralFoam behavior after restart...
Like Tree1Likes
Old   November 10, 2011, 12:01
Alberto Passalacqua
Originally Posted by praveen View Post
Though there was a redundancy, I dont think phi was the problem. Time step does not seem to have been properly set for restarted cases. The below fix is also required for the same bug that vkrastev reported
https://github.com/OpenFOAM/OpenFOAM...99a8dbd3dbf211
The flux phi was locally re-declared inside the main function. This made the local value accessible to the all the instructions explicitly present in the main function. However an inconsistent value was provided to the turbulence model, whose autoPtr is declared in createFields.H, outside the main().
Other problem that was going to happen: the stored "phi" was the one declared in createFields. The one locally re-declared in main was not stored at all, since its IOobject write option is not set to AUTO_WRITE.
This would have led to an inconsistent value of phi at restart, which was causing the problem.
Best,
Alberto Passalacqua
Old   November 10, 2011, 12:02
Alberto Passalacqua
Originally Posted by laurensvd View Post
A beginners question (but googling for commit doesnt seem to work ), how do you 'commit' such an update? Is it related to svn (my it-administrator doesnt allow this)? If its just the rhoCentralFoam.C or rhoCentralFoam.H that is changed, could someone post this change so I can manually fix it if commit is no option? If the only change is the deletion of this one line of code for phi and adding the other as mentioned above, forget I asked something
Instructions on how to use the git repository are available on the OpenFOAM website:
http://www.openfoam.org/git.php
Alberto Passalacqua
Old   November 10, 2011, 12:04
Alberto Passalacqua
OK. Is phi used for some other purpose ? Why aren't the other fluxes phiUp and phiEp similarly declared in createFields.H ? Would like to understand this since I have modified rhoCentralFoam for my own needs.
This is more C++ and programming than CFD :-)
Phi is passed to the turbulence model using via the autoPtr. The two fluxes phiUp and phiEp are not required outside the main() function, so it is perfectly fine not to declare them outside of it.
vkrastev likes this.
Alberto Passalacqua
Old   November 10, 2011, 12:18
Praveen. C
praveen is on a distinguished road
Thanks. I was still looking at 1.7 and hence did not see that phi is used in the turbulence model in 2.0
praveen is offline   Reply With Quote
Old   November 10, 2011, 12:22
Alberto Passalacqua
OK. Just keep in mind that also in 1.7, if you re-declare phi, the stored (to disk) value is not correct.
Best,
Alberto Passalacqua
Old   November 19, 2013, 03:05
Rahul Soni
srahul is on a distinguished road
Hello Mr. Vesselin Krastev,
I went through your post and I was wondering where should in make chnages as outlined by you regarding the bug.
Reagrds,
Rahul
Originally Posted by vkrastev
Hi all,
there was actually a problem in the updating of the flux phi, which has been fixed today with the following OF-2.0.x commit
commit dc17e722ab2a9539775eec59650e6dc0e7eb9360
The bug is present both in OF-1.7.x and OF-2.0.x families, and can be fixed in the same way also for 1.7.x. I think it is important to know for all users that if not fixed, that bug can lead to significantly erroneous results using rhoCentralFoam, as an error seems to propagate through time because of the incorrect phi update (see this page for more details http://www.openfoam.com/mantisbt/view.php?id=332 )
Best
V.
srahul is offline   Reply With Quote
Old   November 19, 2013, 09:34
Vesselin Krastev
vkrastev is on a distinguished road
Reagrds,
Rahul
Hi all,
Best
V.
Hi Rahul,
if you are using a recent OpenFOAM release (any release from 2.0.x till the present 2.2.2/2.2.x) the problem is already fixed and you don't need to do anything. Otherwise, follow the link which points to the Mantis bug tracker discussion about this issue and you will see how to fix it.
Regards
V.
vkrastev is offline   Reply With Quote
Old   November 19, 2013, 13:04
Rahul Soni
Hi, Mr. Vesselin,
Many thanks for your reply I am using the latest version that means the bug is already fixed, once again thank you for you prompt reply.
Regards,
Rahul
Problem with multiframe restart of two-way fsi coupled problem Dimone CFX 26 December 20, 2011 11:10
Restart for solidification atulverma FLOW-3D 2 May 15, 2009 07:25
Restart for Solidification atulverma FLOW-3D 3 May 6, 2009 18:40
v4 restart bug optima prime Siemens 3 February 2, 2009 23:51
Restart of FSI simulation V. Kumar CFX 3 July 20, 2006 14:23
