July 23, 2011, 11:37 |
UNV to OF conversion
Greetings, colleagues.
Probably, I found bug in ideasUnvToFoam. I've created mesh in Salome 6.3.0 and converted it into OF using ideasUnvToFoam. The mesh was damaged during conversion. I attach 2 png-files which explain the problem. The unv-file and the result of it's conversion into OF format may be downloaded by following link: http://files.mail.ru/MRBVD3 OF version: 1.7.1 OS: OpenSUSE 11.4 64 bit The simulation problem is flow in 2D tube around gaussian-like obstacle. Best regards, Aleksey. |
July 25, 2011, 18:18 |
At last, I solved this problem. Solution: scale mesh with coefficient 100 -> save in .unv -> convert to OpenFOAM format -> scale 0.01.
It appeared that OpenFOAM converter fails to read small quantities... |
bug, ideasunvtofoam |
Mesh conversion exits prematurely (Salome to OF) | DMcP | OpenFOAM | 1 | May 16, 2024 10:35 |
[Salome] unv mesh corrupted after createPatch | maddalena | OpenFOAM Meshing & Mesh Conversion | 1 | February 18, 2010 08:43 |
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen | su_junwei | OpenFOAM Meshing & Mesh Conversion | 2 | July 27, 2008 00:58 |
[Salome] UNV IO Source Code | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 4 | March 7, 2008 09:47 |
Energy Conversion Systems (Power and Pro.) Tools | Gordan Feric / Engineering Software (EngWare) | Main CFD Forum | 0 | August 27, 2001 00:14 |
