Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SnappyHexMesh OF-1.6-ext crashes on a parallel run
Old   November 30, 2010, 10:25
Default SnappyHexMesh OF-1.6-ext crashes on a parallel run
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
Dear all,
I got a crush running snappyHexMesh in parallel on 1.6-ext on one of my cases. I run snappyHexMesh in parallel on the motorBike tutorial to test the OF-1.6-ext snappyHexMesh version and it crushed too reporting these errors:
Truncating neighbour list at 12041 for backward compatibility
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 82
Truncating neighbour list at 12560 for backward compatibility
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Problem. oldPointI:5728 newPointI:-1
[0]
[0] From function fvMeshDistribute::mergeSharedPoints()
[0] in file directTopoChange/fvMeshDistribute/fvMeshDistribute.C at line 612.
[0]
FOAM parallel run aborting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Problem. oldPointI:5432 newPointI:-1
[1]
[1] From function fvMeshDistribute::mergeSharedPoints()
[1] in file directTopoChange/fvMeshDistribute/fvMeshDistribute.C at line 612.
[1]
[1]
The same case run well in parallel in 1.5-dev.
Kind Regards
Norman
norman1981 is offline   Reply With Quote
Old   November 30, 2010, 11:47
Elvis
elvis will become famous soon enough
Hi Norman,
there is a Bug Tracker made for the Extend version.
read http://www.extend-project.de/project...nd-bug-tracker
Your Bug Report should go to http://sourceforge.net/apps/mantisbt.../main_page.php
greets
elvis
elvis is offline   Reply With Quote
Old   December 1, 2010, 04:24
norman1981's Avatar
Norman Del Puppo
Originally Posted by elvis View Post
Hi Norman,
greets
elvis
Hi Elvis,
thank you. Yesterday I had a look at sourceforge mantis bug tracker before posting my message but there's not a "Core" (or something related) element in the "Choose Project" combo box therefore I thought this was still the right place to post core-related bugs :-)
Regards
Norman
Old   November 25, 2011, 09:55
Ali Q Raeini
aliqasemi is on a distinguished road
Originally Posted by norman1981 View Post
Dear all,
[0]
[0]
[0]
[0]
[0]
with errorcode 1.
[1]
[1]
[1]
[1]
[1]
Kind Regards
Norman
Dear Norman,
I am getting the same error. Have you got any fix/workaround for this? Or should I use another version of the OpenFOAM?
Thanks in advance.
Ali
aliqasemi is offline   Reply With Quote
Old   November 29, 2011, 05:34
Ola Widlund
Ola Widlund is on a distinguished road
Hi!
I think you would be better off having a fresh OF-2.0 installation as a complement to 1.6-ext. I don't think snappyHexMesh is worked on by anyone in the extend team, so now you are actually using the 1.6 version of snappyHexMesh. There are a lot of developments since then; see release notes on www.openfoam.com.
Of course, nothing prevents you from using your generated mesh with solvers built with the 1.6-ext release.
/Ola
Ola Widlund is offline   Reply With Quote
Old   December 7, 2011, 13:48
Ali Q Raeini
Originally Posted by Ola Widlund View Post
Hi!
/Ola
Thank you Ola,
Unfortunately, at the moment OF-2.0.x does not produce good quality meshes for me. I need a coarse mesh with no feature-edge handelling, roughly speaking. So it seems that I have to use the sHM in OF-1.6-ext - in serial - for now.
Ali
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 05:04
Parallel run diverges, serial does not SammyB OpenFOAM Running, Solving & CFD 1 May 10, 2009 04:28
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 10:54
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 21:46
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 09:53
