Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
blockMesh incorrectly attempts matching wrong cyclic faces (2 out of 3 works)
Old   October 25, 2010, 21:03
Default blockMesh incorrectly attempts matching wrong cyclic faces (2 out of 3 works)
kjetil is on a distinguished road
I have created a neat cyclic+wedge mesh, but blockMesh refuses to "pair" one of the cyclic patches. I have checked vertices and blocks over and over again, and I don't think these are the problem anymore - unless there are some untold restrictions regarding the blocks arrangement.
Error message follows:
--> FOAM FATAL ERROR:
face 12 area does not match neighbour 64 by 8.7206% -- possible face ordering problem.
patch:inlet my area:1.5771e-05 neighbour area:1.44531e-05 matching tolerance:0.001
Mesh face:2418 vertices:4((0.00758169 0.0061177 0.1056) (0.00887663 0.00606116 0.1056) (0.00887663 -0.00606116 0.1056) (0.00758169 -0.0061177 0.1056))
Neighbour face:2470 vertices:4((0.0205312 0.00555231 0.1364) (0.0192362 0.00560885 0.1364) (0.0192362 -0.00560885 0.1364) (0.0205312 -0.00555231 0.1364))
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 179.
FOAM exiting
Now, the blockMeshDict file is attached, and the vertices making up the two patches are 13 to 16, and 26 to 29. They points in space are all perfectly specified, where only the z value differs between the patches. So is also the block definition.
The successfull en patches can be seen in red. The blue one inbetween is the one affected and which so far is unable to be added as a part of the cyclic patch.
kjetil is offline   Reply With Quote
blockmesh, cyclic, error, wedge
udf error srihari FLUENT 1 October 31, 2016 15:18
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
blockMesh prism undefined faces flowris OpenFOAM 3 May 25, 2010 12:07
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
