Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
mutRoughWallFunction on OF 1.7.0
Old   September 2, 2010, 03:23
Default mutRoughWallFunction on OF 1.7.0
OMN
Olivier Macchion
OMN is on a distinguished road
Hello
I tried to set up a rough wall for a run with buoyantSimpleFoam in OF 1.7 using the syntax:
wall
type mutRoughWallFunction;
Ks uniform 0.005;
Cs uniform 0.5;
value uniform 0;
and I got this error message after starting buoyantSimpleFoam:
Selecting RAS turbulence model realizableKE
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 log in "/lib/tls/i686/cmov/libm.so.6"
#4 Foam::compressible::RASModel::yPlusLam(double, double) const in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#5 Foam::compressible::RASModels::mutRoughWallFunctio nFvPatchScalarField::calcMut() const in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#6 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#7 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/buoyantSimpleFoam"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/opt/openfoam170/applications/bin/linuxGccDPOpt/buoyantSimpleFoam"
#9 Foam::compressible::RASModels::realizableKE::reali zableKE(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#10 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::realiza bleKE>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#12
#13 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#14
Floating point exception
Would someone know what the problem is? Everything works fine with mutWallFunction.
I also tried to use mutRoughWallFunction in the hotroom tutorial for buoyantSimpleFoam but I got the same error message. I also tried this with rhoPorousSimpleFoam and got the same error message. Is this a bug or my lack of understanding of the use of mutRoughWallFunction?
Cheers
Olivier
OMN is offline   Reply With Quote
Old   September 2, 2010, 04:09
Mattijs Janssens
mattijs is on a distinguished road
We've finally got a proper bug reporting system :-)
Please report any 1.7 bugs on http://www.openfoam.com/bugs.
Thanks,
Mattijs
mattijs is offline   Reply With Quote
Old   September 20, 2010, 12:27
Default same problem with 1.7.x (git of today)
Thomas Wolfanger
anger is on a distinguished road
Hi Olivier,
I checked your and andy's communication on the bug tracker; is the issue resolved for you?
Background: I tried the same for rhoPorousSimpleFoam with the angledDuctImplicit tutorial case. All my efforts failed miserably and I did not get the case to run, even with initializing all values in the 0/mut file (error message below).
Selecting RAS turbulence model kEpsilon
#0 Foam::error:rintStack(Foam::Ostream&) in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 ?? in "/lib/libm.so.6"
#4 log in "/lib/libm.so.6"
#5 Foam::compressible::RASModel::yPlusLam(double, double) const in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#6 Foam::compressible::RASModels::mutRoughWallFunctio nFvPatchScalarField::calcMut() const in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#7 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#8 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/soft/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/soft/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
#10 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#12 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/soft/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#13 main in "/soft/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
#14 __libc_start_main in "/lib/libc.so.6"
#15 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
To my surprise the case ran through valgrind; I'm in no way an expert what this could mean, but probably an initialisation issue exists. What else did you change to get the case running?
Regards,
Thomas
anger is offline   Reply With Quote
Old   September 21, 2010, 03:06
Default I initialized with mutWallFunction
OMN
Olivier Macchion
Hello
I ran the case with mutWallFunction for about 100 iterations, then I switched to mutRoughWallFunction. But I did that on my own case, not the tutorial. But it should work: it is indeed an initialization problem. But it is weird that it would affect the solution so strongly.
Kind regards
Olivier
Old   September 21, 2010, 04:30
Default Problem found (but not understood)
Thomas Wolfanger
thanks for your input, Olivier.
Sadly, this did not work for me so I tried to track down this issue.
The problem comes from ypl getting negative at around line 166 of file RASModel.C, so catching this resolves the issue technically; however I do not know what this means physically, i.e. whether an error may be introduced here.
Maybe someone having more insight into the OF internals can comment on this.
Best regards,
Thomas
Old   November 10, 2010, 12:23
Default trying to use mutRoughWallFunction with kOmegaSST in rhoSimpleFoam
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
I got same messages when trying to use mutRoughWallFunction with kOmegaSST in rhoSimpleFoam.
Is it a confirmed bug? Did someone know how to use wall functions wiht roughness?
aerothermal is offline   Reply With Quote
Old   November 10, 2010, 14:06
Guilherme da Silva
just try
export FOAM_SIGFPE=false
or
unset FOAM_SIGFPE
Old   November 12, 2010, 04:05
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
find the file RASModel.C
in src/turbulenceModels/compressible/RAS/RASModel
and modify the line to calculate ypl to whats below
scalar RASModel::yPlusLam(const scalar kappa, const scalar E) const
    scalar ypl = 11.0;
    for (int i=0; i<10; i++)
      ypl = log(max(E*ypl,1.0))/kappa;
    return ypl;
then goto src/turbulenceModels/compressible/RAS
and type wmake libso
now try it again. Does that work better?
niklas is offline   Reply With Quote
Old   November 12, 2010, 09:47
Default Other bugs in model implemented in mutRoughWallFuntion
Guilherme da Silva
    scalar ypl = 11.0;
    return ypl;
Thank you. It makes sense in order to prevent log(0) calculation. I will implement it anyway.
However, I have found another potential bugs in equations of mutRoughWallFunction. The implementation does not reflect the mathematical modelling found in some references:
In order to fix that bug, I implemented additional changes to the code, which I called mymutRoughWallFunctionFvPatchScalarField.C. As you can see, I commented out the original lines for reference and traceability.
tmp<scalarField> mymutRoughWallFunctionFvPatchScalarField::calcMut() const
    const label patchI = patch().index();
    const RASModel& rasModel = db().lookupObject<RASModel>("RASProperties");
    const scalarField& y = rasModel.y()[patchI];
    const scalarField& rhow = rasModel.rho().boundaryField()[patchI];
    const tmp<volScalarField> tk = rasModel.k();
    const volScalarField& k = tk();
    const scalarField& muw = rasModel.mu().boundaryField()[patchI];
    const scalar Cmu25 = pow(Cmu_, 0.25);
    tmp<scalarField> tmutw(new scalarField(*this));
    scalarField& mutw = tmutw();
    forAll(mutw, faceI)
        label faceCellI = patch().faceCells()[faceI];
        scalar uStar = Cmu25*sqrt(k[faceCellI]);
        scalar yPlus = uStar*y[faceI]/(muw[faceI]/rhow[faceI]);
        scalar KsPlus = uStar*Ks_[faceI]/(muw[faceI]/rhow[faceI]);
//	scalar Edash = E_;
        scalar Edash = 0;
        scalar yPlusLamNew = yPlusLam_;
        if (KsPlus > 2.25)
	    /* it was
            yPlusLamNew = rasModel.yPlusLam(kappa_, Edash);
            Edash /= fnRough(KsPlus, Cs_[faceI]);*/
	    /* it becomes */
            Edash = 1/kappa_*log(fnRough(KsPlus, Cs_[faceI]));
            yPlusLamNew = rasModel.yPlusLam(kappa_, E_);
        if (debug)
            Info<< "yPlus = " << yPlus
                << ", KsPlus = " << KsPlus
                << ", Edash = " << Edash
                << ", yPlusLam = " << yPlusLam_
                << endl;
        if (yPlus > yPlusLamNew)
	    /* it was
            mutw[faceI] =
                muw[faceI]*(yPlus*kappa_/log(max(Edash*yPlus, 1+1e-4)) - 1);
	    Calculation from OpenFOAM original mutWallFunction (smooth wall!!)
            mutw[faceI] = muw[faceI]*(yPlus*kappa_/log(E_*yPlus) - 1);*/
		log(max(E_*yPlus/exp(kappa_*Edash),1+1e-4)) - 1);
    return tmutw;
I already run a rough cylinder flow of Re 2.2E5, heat transfer from isothermal wall at 333.15 K and freestream temperature of 303.15. The original OpenFoam gave me a Cp lowest value between the potential solution and the experimental; and provided me a Frossling (which is Nu/sqrt(Re)) three times less than experimental. With the new implementation, everything is in the same order. Both Frossling and Cp are very close to experimental data.
Regards,
Guilherme
Old   November 12, 2010, 17:39
Guilherme da Silva
E is a constant (non-zero).
yplus is 11 at the start and is calculated....
How does it go to zero anyway?
Old   June 14, 2011, 12:07
ak
newOFuser is on a distinguished road
Hi
I tried "unset FOAM_SIGFPE" in the .bashrc file followed by the “. $HOME/.bashrc” command, but when I run the case, I still get the following before the simulation starts:
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
SetNaN : Initialising allocated memory to NaN (FOAM_SETNAN).
I tried "export FOAM_SIGFPE=false" as well but that didn't work either.
Do we have to run ./Allwmake in the top-level source directory $WM_PROJECT_DIR as well?
Can anyone who has successfully unset sigFpe provide the details?
Sorry, it seems like it is easy to implement, but I am new to using OF, and would appreciate any help.
Thanks so much.
ak
newOFuser is offline   Reply With Quote
Old   December 13, 2011, 08:11
rgarcia is on a distinguished road
Hi all,
I have a quick and probably stupid question...
I don't understans the code line: "scalar Edash /= E_"
Even when E_ has not been initialised.
Thank you in advance.
Roger
rgarcia is offline   Reply With Quote
wall functions
OpenFOAM 1.7.0 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 1 May 26, 2011 04:09
mutRoughWallFunction OMN OpenFOAM 1 November 10, 2010 14:09
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 06:51
interFoam 1.7.0: continuityErrs.H in PSIO loop idrama OpenFOAM 1 July 8, 2010 03:56
Installation of OpenFOAM 1.7.0 on SLED10SP2 olauer OpenFOAM Installation 2 June 30, 2010 11:29
