Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
surface output format; raw
Old   May 5, 2010, 06:13
Default surface output format; raw
Kim Yusik
impecca is on a distinguished road
when I use surface sample function on prime2Mean field with format of 'raw', there is no space between xz(u'w') and yy(v'v') components (which mean 2 number stuck together. so I can't use xz, yy component on postprocessing)
1.6.x and 1.6 gave me same problem.
I attached output file, you can see what is problem between these 2 components.
(order of data is x, y, z, u'u', u'v', u'w', v'v', v'w', w'w')
is there anyone who faced and fixed this problem?
Thanks
impecca is offline   Reply With Quote
Old   May 6, 2010, 15:59
Volker Tritschler
volker is on a distinguished road
yes, I recognized the same. A workaround might be to sample each component separately and hence to treat them likewise in the post processing.
But it's definitively a bug!
volker is offline   Reply With Quote
Old   May 7, 2010, 05:16
henry is on a distinguished road
Thank for the bug-report. This is now fixed in OpenFOAM-1.6.x
H
henry is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 13:19
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 13:48
CFX4: Free surface grid movement algorithm JEYA CFX 0 November 7, 2007 08:47
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 07:27
