settlingFoam fails with timeVarying conditions on U |
April 20, 2010, 22:32 |
Alberto Passalacqua
Rep Power: 36 |
Bug settlingFoam fails when a timeVarying boundary condition is used for the U field, since Vdj inherits the boundaryField from U, leading the code to a segmentation fault when Vdj.correctBoundaryConditions(); is executed. Proposed solution I'm not sure why Vdj inherits the BC's from V, since it is computed explicitly. However a workaround could be to replace the declaration of Vdj in createFields.H with (I left the commented line). Code:
volVectorField Vdj ( IOobject ( "Vdj", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("0.0", U.dimensions(), vector::zero) //,U.boundaryField().types() );
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 21, 2010, 15:16 |
#2 | |
Fran
Rep Power: 17 |
The bug also exists for alpha BC, since Alpha inherits the boundaryField from alpha.
I tried a similar fix for this BC. Code:
volScalarField Alpha ( IOobject ( "Alpha", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), alpha*rhod/rho //,alpha.boundaryField().types() ); But I get the next error message when trying to run the case: Quote:
volScalarField Alpha ( IOobject ( "Alpha", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh // alpha*rhod/rho //,alpha.boundaryField().types() ); It seems to work fine, but I had to manually calculate and create the Alpha bondaryField File in the 0 folder, and apply the timeVaryingUniformFixedValue to this BC instead of applying it to alpha. P.S.: Note the difference between alpha and Alpha. Alpha= alpha*rhod/rho Last edited by lfbarcelo; April 21, 2010 at 17:42. Reason: Found a solution |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
InterDyMFoam dynamic messing in parallel fails under nonquiescent conditions | adona058 | OpenFOAM Running, Solving & CFD | 5 | August 19, 2010 12:47 |
InterDyMFoam dynamic meshing in parallel fails under nonquiescent conditions | adona058 | OpenFOAM Bugs | 7 | November 18, 2008 15:58 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 07:25 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
