Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Particles are not hitting the wall
Like Tree1Likes
Old   November 7, 2014, 12:52
Default Particles deflected by surface defined as stick
  #21
Michael
lithos is on a distinguished road
Dear all,
I'd like to add an incident to this thread as it seems to be a similar problem. The cases concerned introduce parcels into a thermal plume. This flow "hits" a bend surface. Different aerodynamic diameters have been used, i.e. 1e-4, 1e-5 and 1e-6.
I used paraview to animate the flow of the parcels and it seems that they are deflected from the wall, see (10 and 50 MB file size; red particles are active = flowing, blue are stick)
https://box.cern.ch/public.php?servi...1933015dd82303
and
https://box.cern.ch/public.php?servi...519d51c73f7e33
This surface is definitely set to stick,
                type        stick;
and for some particle diameters it works, for some it does not (see attached screenhots). CheckMesh seems fine with the tets, log file attached as well
Does anybody of you have an idea what is (not) going on there? Is a certain mesh resolution necessary depending on a parcel size? Could this be a scheme or solution problem (both attached)?
OpenFOAM version is 2.2.x-5cc33a231685. Solver used is fireFoam version 70b3e6a20900683fba46801c31725a9197954ecb.
Thanks in advance for any kind of help.
Cheers,
Michael
lithos is offline   Reply With Quote
Old   June 2, 2015, 05:33
luchen
luchen2408 is on a distinguished road
hello, my test simulation also shows that the partiles will stick to the all and will flow along the wall for a long distance. beside, the gravity doesn't act on the particles. is there any suggestion to solve the problems?
luchen2408 is offline   Reply With Quote
Old   May 19, 2016, 07:04
Albrecht vBoetticher
vonboett is on a distinguished road
Yust an idea: did you make shure that your maxInteractionDistance is larger than your max. particle diameter?
vonboett is offline   Reply With Quote
Old   May 19, 2016, 21:29
luchen
Yes, I think so, now the gravity act on the particles.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Particles do not hit the wall CedricVH OpenFOAM 0 April 15, 2010 09:21
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Near wall particles Staffan FLUENT 2 October 2, 2000 09:47
