latest OpenFOAM-1.6.x from git failed to compile |
January 3, 2010, 12:39 |
#21 |
Ahmed
Rep Power: 18 |
it is a 68 Byts file, and its contents are
Pstream.C IPread.C OPwrite.C LIB = $(FOAM_LIBBIN)/dummy/libPstream these three files are available into the folder OpenFOAM/OpenFOAM-1.6.x/src/Pstream/dummy Michael, I guess I understand what you mean, so if g++ cannot find these files it is because an environment variable or variables are not correctly defined. After that failed compilation, I ran the foamInstallationTest utility, and there are critical variables that are incorrectly defined, here is the output Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/ahmed/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/ahmed/OpenFOAM/ahmed-1.6.x yes no $WM_THIRD_PARTY_DIR /home/ahmed/OpenFOAM/ThirdParty-1.6.x yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/ahmed/OpenFOAM/OpenFOAM-1.6.x yes yes yes $FOAM_APPBIN ...6.x/applications/bin/linux64GccDPOpt no yes $FOAM_SITE_APPBIN ...nFOAM/site/1.6.x/bin/linux64GccDPOpt no no $FOAM_USER_APPBIN ...6.x/applications/bin/linux64GccDPOpt no no $WM_DIR .../ahmed/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...nFOAM/site/1.6.x/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN ...FOAM/ahmed-1.6.x/lib/linux64GccDPOpt no no $MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt yes yes yes ------------------------------------------------------------------------------- Right now, I am a bit confused, these variables are assigned during the compilation based on the bashrc definitions and the settings.sh and no intervention from my side, what might have caused this to happen to me. truly, I will be glad to receive your reply Good luck to all, and thanks again |
January 3, 2010, 12:50 |
#22 |
Michael Wild
Rep Power: 17 |
The only thing in your listing that is strange is FOAM_APPBIN. What does it point to? But anyways, I would be very surprised if that was the reason...
To me it seems as if wmake wasn't able to correctly read/preprocess Make/{options,files}. What does $FOAM_SRC/Pstream/dummy/Make/$WM_OPTIONS contain? Does the file filesMacros exist in there, and what are its contents? Michael |
January 3, 2010, 14:06 |
#23 |
Ahmed
Rep Power: 18 |
I guess you are on the right track, the file filesMacros is an empty document (0 bytes)
Well it is not the only one, the files contained into the directory $FOAM_SRC/Pstream/dummy/Make/$WM_OPTIONS are 1- dependencies 24B {dependencies up to date } 2- dependencyFiles 16B {DEPENDENCIES = } 3- dontIncludeDeps 0B 4- files 0B 5- filesMacros 0B 6- includeDeps 0B 7- localObjectFiles 17B {LOCAL_OBJECTS = } 8- objectFiles 11B {OBJECTS = } 9- options 0B 10- sourceFiles 10B {SOURCE = } where the contents of the None Zero files is written between the curly braces and here we have the env variables:- ahmed@linux-z5ms:~> echo $FOAM_APPBIN /home/ahmed/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt ahmed@linux-z5ms:~> echo $FOAM_SITE_APPBIN /home/ahmed/OpenFOAM/site/1.6.x/bin/linux64GccDPOpt ahmed@linux-z5ms:~> echo $FOAM_USER_APPBIN /home/ahmed/OpenFOAM/ahmed-1.6.x/applications/bin/linux64GccDPOpt ahmed@linux-z5ms:~> echo $WM_DIR /home/ahmed/OpenFOAM/OpenFOAM-1.6.x/wmake ahmed@linux-z5ms:~> echo $FOAM_SRC /home/ahmed/OpenFOAM/OpenFOAM-1.6.x/src ahmed@linux-z5ms:~> echo $FOAM_SRC/Pstram/dummy/Make/$WM_OPTIONS /home/ahmed/OpenFOAM/OpenFOAM-1.6.x/src/Pstram/dummy/Make/linux64GccDPOpt |
January 3, 2010, 20:50 |
#24 | |
J. Cai
Rep Power: 17 |
Hi, Mattijs, even I revise the tecioOptions file as
HTML Code:
TECIO_FLAGS = -DMAKEARCHIVE -DLINUX DLINUXI64 -DUSEENUM -DTHREED -U_WIN32 TECIO_INC = TECIO_LIBS = HTML Code:
# 1 "options" # 1 "<built-in>" # 1 "<command line>" # 1 "options" # 1 "tecioOptions" 1 TECIO_FLAGS = -DMAKEARCHIVE -DLINUX -DUSEENUM -DTHREED -U_WIN32 # 15 "tecioOptions" TECIO_INC = TECIO_LIBS = # 2 "options" 2 EXE_INC = $(TECIO_FLAGS) $(TECIO_INC) LIB_LIBS = $(TECIO_LIBS) Chiven Quote:
January 29, 2010, 15:54 |
#25 |
Rep Power: 17 |
Hi Everyone,
not sure whether this is related to the previous problems as I am very new to linux and compiling. I followed albertos manual to install OF1.6 on opensuse 11.2 but i get an error when compiling from git. unfortunately i cannot comprehend where exactly the problem is located. could someone help me out? here is the last bit of the log: Code:
-lspecie -lmeshTools -lOpenFOAM -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/IFCLookUpTableGen make[2]: Leaving directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/IFCLookUpTableGen' make[2]: Entering directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT' Making dependency list for source file mixtureAdiabaticFlameT.C make[2]: Leaving directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT' make[2]: Entering directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT' SOURCE=mixtureAdiabaticFlameT.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/phi/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o -L/home/phi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT make[2]: Leaving directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT' make[1]: Leaving directory `/home/phi/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical' make: Target `application' not remade because of errors. cheers, chris |
February 9, 2010, 05:37 |
#26 |
David
Rep Power: 16 |
Hi Ahmed
I have the same error than you when I try to compile wmake libso finiteVolume after add a new boundary condition patch. Have you solved this probelm? Tankyou very much David |
Latest git 1.6.x : cellDistFuncs.H | podallaire | OpenFOAM Bugs | 4 | December 11, 2009 09:03 |
Latest git 1.6.x: Crash when using inletOutlet for variable alpha1 in interFoam | carsten | OpenFOAM Bugs | 6 | September 23, 2009 10:46 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 22:51 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
