Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Possible bug with tensor2D
Old   December 7, 2009, 20:49
Default Possible bug with tensor2D
Sandeep Menon
deepsterblue will become famous soon enough
The following source fails to compile:
#include "tensor2D.H"
#include "IOstreams.H"
using namespace Foam;
int main()
    tensor2D t1(1, 2, 3, 4);
    tensor2D t2(1, 2, 3, 1);
    tensor2D tt2 = (t1 & t2);
    Info << tt2 << endl;
    return(0);
It returns the following error:
tensor2DTest.C: In function ‘int main()’:
tensor2DTest.C:11: error: conversion from ‘Foam::Tensor<double>’ to non-scalar type ‘Foam::tensor2D’ requested
/home/smenon/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Tensor2DI.H: In function ‘typename Foam::innerProduct<Foam::Tensor2D<Cmpt>, Foam::Tensor2D<Cmpt> >::type Foam::operator&(const Foam::Tensor2D<Cmpt>&, const Foam::Tensor2D<Cmpt>&) [with Cmpt = double]’:
tensor2DTest.C:11:   instantiated from here
/home/smenon/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Tensor2DI.H:187: error: conversion from ‘Foam::Tensor2D<double>’ to non-scalar type ‘Foam::Tensor<double>’ requested
make: *** [Make/linux64GccDPOpt/tensor2DTest.o] Error 1
This seems odd, since the operator overload is clearly defined in Tensor2DI.H, and I'm not performing any conversions from tensor2D to tensor. Any ideas?
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 8, 2009, 03:17
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
/home/smenon/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Tensor2DI.H: In function typename Foam::innerProduct... :
Did you look at 1.6.x first?
If you do, you'll see that this has been fixed. And you'll also see why was previously failing.
Specifically, take a look at commit d8d420a364ddc2b368063f994ca589bccf17a2ed
olesen is offline   Reply With Quote
Old   December 10, 2009, 16:01
Sandeep Menon
Mark,
Thanks for pointing me in the right direction...
Call me a git-noob, but is there some way that I can browse the repository (in a web-browser perhaps) to look at a specific revision / commit? I'm looking to avoid downloading the entire thing...
Sandeep Menon
Old   December 10, 2009, 16:08
Sandeep Menon
Oops... Never mind.
For those interested... The link is:
http://repo.or.cz/w/OpenFOAM-1.6.x.git/shortlog
Sandeep Menon
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 chiven OpenFOAM Bugs 18 April 18, 2013 23:56
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 09:15
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
Win XP hot fix bug!!! Emilio Siemens 1 March 27, 2003 13:06
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 11:22
