Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Latest git 1.6.x : cellDistFuncs.H
Old   September 15, 2009, 18:25
Default Latest git 1.6.x : cellDistFuncs.H
Pierre-Olivier Dallaire
podallaire is on a distinguished road
just want to report some missing links when compiling the latest git / can see this error many times :
OpenFOAM/OpenFOAM-1.6.x/src/meshTools/lnInclude/cellDistFuncs.H:166:39: error: cellDistFuncsTemplates.C: No such file or directory
Thanks
PO
podallaire is offline   Reply With Quote
Old   September 15, 2009, 19:13
Mattijs Janssens
mattijs is on a distinguished road
It's a new file and hasn't been linked to the lnInclude directory. Just remove the lnInclude directory in the meshTools directory and 'wmake libso' (or Allwmake from the top level)
mattijs is offline   Reply With Quote
Old   December 11, 2009, 07:42
Default similar problem...
Matteo Carpentieri
mcarpe is on a distinguished road
thanks for the hint on the previous post. It solved the issue, then.
Now I'm getting similar errors with the latest git version of 1.6.x.
In particular, this is the error that keeps popping up during the compilation:
lnInclude/stringListOps.H:43:31: error: wordReListMatcher.H: No such file or directory
...and many others, always related to this wordReListMatcher.H file.
Any thought?
thanks
mcarpe is offline   Reply With Quote
Old   December 11, 2009, 08:24
Mattijs Janssens
This file (is new) is not in your lnInclude directory. Clear out your lnInclude directory so as to force a rebuild of it. wcleanLnInclude can be used to clear the lnInclude directory.
Old   December 11, 2009, 09:03
Matteo Carpentieri
Yep! It worked.
Thanks a lot.
There was another compilation error, though:
make[3]: *** No rule to make target `curevedEdgeList.H', needed by `blockMeshApp.dep'.
I solved that issue just entering into the 'blockMesh' source directory, 'wclean' and then building it again with 'wmake'.
git problem with http repository az_monger OpenFOAM Bugs 2 September 4, 2009 06:45
Question about obtaining the latest version rauld OpenFOAM Bugs 10 August 25, 2009 11:26
git svn clone of openfoam-extend Bost OpenFOAM 12 August 3, 2009 21:16
Installation Problem with GIT sega OpenFOAM Installation 2 May 8, 2009 09:46
OpenFOAM Patched Version 1.5 via git Repository OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2008 06:06
