Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
mapFields ignores sourceTime for -parallel source
Old   September 2, 2009, 02:51
Default mapFields ignores sourceTime for -parallel source
Andrew King
andersking is on a distinguished road
When using mapFields, and mapping from a parallel source the -sourceTime flag is ignored if the time doesn't exist in the top case directory (it maps from 0 instead). ie.
if you have a case directory structure like so
case/
case/0
case/constant
case/system
case/processor0
case/processor0/constant
case/processor0/0
 case/processor0/500
case/processor1
case/processor1/constant
 case/processor1/0
  case/processor1/500
using mapFields as follows
mapFields ../test/ -sourceTime 500 -parallelSource
ignores the sourceTime and instead maps from 0 (but correctly maps it from the processor dirs).
When using parallel source, it should check to see if the time exists in the processor dir's not the root case.
As a workaround using
mkdir 500
in the root case fixes it, and it maps from the correct source time.
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   September 2, 2009, 07:49
henry is on a distinguished road
Thanks for the bug report. I have pushed a fix into OpenFOAM-1.6.x please let us know if it works for your case.
H
henry is offline   Reply With Quote
Old   September 2, 2009, 11:38
Andrew King
Hi Henry,
Works now. Thanks
Andrew
Dr Andrew King
Curtin University
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
