Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Allwmake error: /usr/bin/ld: cannot find -lautoMesh
Old   July 28, 2009, 22:50
Default Allwmake error: /usr/bin/ld: cannot find -lautoMesh
qqj
ranas is on a distinguished road
i got the error after executing Allwmake
collect2: ld returned 1 exit status
make[2]: *** [/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamDebugSwitches] Error 1
make[2]: Leaving directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous/foamDebugSwitches'
make[1]: *** [foamDebugSwitches] Error 2
make[2]: Entering directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous/expandDictionary'
make[2]: `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/expandDictionary' is up to date.
make[2]: Leaving directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous/expandDictionary'
make[2]: Entering directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous/foamInfoExec'
make[2]: `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamInfoExec' is up to date.
make[2]: Leaving directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous/foamInfoExec'
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/qqj/OpenFOAM/OpenFOAM-1.5/applications/utilities/miscellaneous'
make: *** [miscellaneous] Error 2
make: Target `application' not remade because of errors.
+ '[' '' = doc ']'
could you give me some advice?
best wish
ranas
ranas is offline   Reply With Quote
Old   July 29, 2009, 03:36
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Ranas
It means that something went wrong while compiling the src-directory of OpenFOAM. At least that it where the library libautoMesh gets compiled.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   August 3, 2009, 22:55
qqj
Hi Niels
Thank you for your reply! I found that there is something wrong about the version 1.5(may be bugs in this version 1.5 ), cause i do not meet any problem compiling version 1.5.x .
best wish
ranas
Looking for SUBOFF model but i can't find it. Heewon Lee Main CFD Forum 7 March 5, 2017 14:36
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Recursive wmake all doesnbt find Allwmake hannes OpenFOAM Bugs 1 April 18, 2007 09:15
where can I find information on Star v4? tootoon Siemens 5 March 11, 2007 17:36
YPlus nowhere to be find Daniel CFX 3 May 1, 2006 17:22
