Postprocessing and uniformDensityHydrostaticPressure in v1.6 |
July 28, 2009, 12:27 |
Julien Schaguene
Rep Power: 17 |
I was glad to see the uniformDensityHydrostaticPressure in OpenFoam 1.6 and try to use it in order to see if this was what I was looking for. The simulation works, I think, but when using paraFoam or foamToVTK, the following error message appears: Time: 0 request for uniformDimensionedVectorField g from objectRegistry region0 failed available objects of type uniformDimensionedVectorField are 0() [...] From function objectRegistry::lookupObject<Type>(const word&) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140. FOAM aborting I know a new version cannot be perfect, but if you have any solution/suggestion, regards, Julien |
July 28, 2009, 13:47 |
Mattijs Janssens
Rep Power: 26 |
It expects the gravity 'g' to be loaded in the objectRegistry which is true for the simulation. As a work-around change (with an editor) the type of the bc into fixedValue so you can postprocess it.
July 28, 2009, 14:41 |
Mattijs Janssens
Rep Power: 26 |
Note: you should only get this problem because you do not have a 'value' entry so the boundary condition needs to do an evaluation.
Postprocessing in 3d - Creating part of a surface | shankara.2 | FLUENT | 0 | July 13, 2009 18:33 |
Question about Postprocessing Using UDF(in tutoria | sarah_ron2002 | FLUENT | 1 | April 10, 2007 17:17 |
Postprocessing in 2D - specific area | Anthony Wachs | FLUENT | 3 | July 6, 2001 11:59 |
postprocessing | bas rijkse | FLUENT | 0 | July 5, 2001 09:30 |
Win NT, pre and postprocessing with large problems | Dirk | FLUENT | 1 | February 7, 2001 15:50 |
