Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
mergeMeshes no handling zones properly
Old   July 4, 2009, 20:32
Default mergeMeshes no handling zones properly
Steve Hansel
hansel is on a distinguished road
OF1.5-dev downloaded 7/3/09 64 bit Ubuntu 9.04
I'm making 2 meshes with blockMesh, one has a zone of A, the other has a zone of B. I merge the two together with mergeMeshes and everything ends up in Zone A, Zone B has zero points, but is listed.
I can send a test case if it helps.
Steve
hansel is offline   Reply With Quote
Old   July 25, 2009, 19:44
Steve Hansel
I looked into this a little more and found this code fragment in mergePolyMesh.C line 431
// Add the zones if necessary
if
pointZoneNames_.size() != pointZones().size()
|| faceZoneNames_.size() != faceZones().size()
|| cellZoneNames_.size() != cellZones().size()
Was this something that was going to be completed later or is that really supposed to be empty?
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 10:33
merge zones Domi FLUENT 2 May 3, 2019 14:15
Require help in "Merging Grid Zones" Nitesh Goyal FLUENT 0 June 13, 2007 11:25
about seperating zones Bono FLUENT 1 October 8, 2005 07:08
Patch-Different values to different zones Pradeep FLUENT 0 April 26, 2005 09:50
