Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel
Old   April 30, 2009, 04:19
Default Segmentation fault when running dieselFoam or dieselEngineFoam in parallel
Francesco Contino
francesco is on a distinguished road
Hi everyone,
It seems that there is some kind of a bug when running dieselEngineFoam in parallel. I've just tested it with the 1.5-dev version and it appears that this application gives a segmentation fault as follows:
[node023:13101] *** Process received signal ***
[node023:13101] Signal: Segmentation fault (11)
[node023:13101] Signal code:  (-6)
[node023:13101] Failing at address: 0x7440000332d
[node023:13101] [ 0] /lib64/libc.so.6 [0x3916e30280]
[node023:13101] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3916e30215]
[node023:13101] [ 2] /lib64/libc.so.6 [0x3916e30280]
[node023:13101] [ 3] /lib64/libc.so.6 [0x3916e71f65]
[node023:13101] [ 4] /lib64/libc.so.6(__libc_malloc+0x7a) [0x3916e7402a]
[node023:13101] [ 5] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_Znwm+0x1d) [0x2b0dc7aa5a7d]
[node023:13101] [ 6] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs4_Rep9_S_createEmmRKSaIcE+0x21) [0x2b0dc7a83341]
[node023:13101] [ 7] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs4_Rep8_M_cloneERKSaIcEm+0x2b) [0x2b0dc7a83beb]
[node023:13101] [ 8] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs7reserveEm+0x41) [0x2b0dc7a84871]
[node023:13101] [ 9] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs6appendEPKcm+0x93) [0x2b0dc7a84ad3]
[node023:13101] [10] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZNK4Foam16DimensionedFieldIdNS_7volMeshEE7averageEv+0x52) [0x2b0dc5ca72b2]
[node023:13101] [11] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZN4Foam5spray24calculateAmbientPressureEv+0x17) [0x2b0dc5cb1ce7]
[node023:13101] [12] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZN4Foam5spray6evolveEv+0x2e2) [0x2b0dc5ca9342]
[node023:13101] [13] dieselEngineFoam [0x419fea]
[node023:13101] [14] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3916e1d974]
[node023:13101] [15] dieselEngineFoam(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0xf1) [0x417869]
[node023:13101] *** End of error message ***
mpirun noticed that job rank 0 with PID 13101 on node node023 exited on signal 11 (Segmentation fault).
[node023:13237] *** Process received signal ***
[node023:13237] Signal: Segmentation fault (11)
[node023:13237] Signal code:  (-6)
[node023:13237] Failing at address: 0x744000033b5
[node023:13237] [ 0] /lib64/libc.so.6 [0x3916e30280]
[node023:13237] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3916e30215]
[node023:13237] [ 2] /lib64/libc.so.6 [0x3916e30280]
[node023:13237] [ 3] /lib64/libc.so.6 [0x3916e71f65]
[node023:13237] [ 4] /lib64/libc.so.6(__libc_malloc+0x7a) [0x3916e7402a]
[node023:13237] [ 5] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_Znwm+0x1d) [0x2b11c8e1da7d]
[node023:13237] [ 6] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs4_Rep9_S_createEmmRKSaIcE+0x21) [0x2b11c8dfb341]
[node023:13237] [ 7] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs4_Rep8_M_cloneERKSaIcEm+0x2b) [0x2b11c8dfbbeb]
[node023:13237] [ 8] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs7reserveEm+0x41) [0x2b11c8dfc871]
[node023:13237] [ 9] /home/term/bberger/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSs6appendEPKcm+0x93) [0x2b11c8dfcad3]
[node023:13237] [10] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZNK4Foam16DimensionedFieldIdNS_7volMeshEE7averageEv+0x52) [0x2b11c701f2b2]
[node023:13237] [11] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZN4Foam5spray24calculateAmbientPressureEv+0x17) [0x2b11c7029ce7]
[node023:13237] [12] /home/term/bberger/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdieselSpray.so(_ZN4Foam5spray6evolveEv+0x2e2) [0x2b11c7021342]
[node023:13237] [13] dieselEngineFoam [0x419fea]
[node023:13237] [14] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3916e1d974]
[node023:13237] [15] dieselEngineFoam(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0xf1) [0x417869]
[node023:13237] *** End of error message ***
I've observed the same problem with dieselFoam on the aachenBomb tutorial case.
These two applications work on serial. Other applications (icoFoam and engineFoam) work fine on the same cluster.
If someone can help me, it would be great.
Francesco.
francesco is offline   Reply With Quote
Old   April 30, 2009, 05:34
Francesco Contino
Here is an input:
I've removed all occurence of the spray inside the application and now it does not give me a segmentation fault anymore.
Is it possible that the dieselSpray library could be a problem here?
Francesco.
Old   October 25, 2010, 12:38
Default I have similar problems with another solver
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Originally Posted by francesco View Post
Here is an input:
Francesco.
It seems that your problem parallels (pun intended) a similar problems with another solver (http://www.cfd-online.com/Forums/ope...ngianfoam.html) post 13 that I had. Did this error get resolved in your case? Without changing to another version of OF.
Dan
chegdan is offline   Reply With Quote
Old   June 10, 2011, 10:30
Default check your constant/sprayProperties and change
mehdi
mehdi-combustion is on a distinguished road
interpolationSchemes
U cellPointFace;
rho cell;
p cell;
T cell;
to
U cell;
rho cell;
p cell;
T cell;
Hope it works
mehdi
mehdi-combustion is offline   Reply With Quote
Old   May 2, 2017, 22:59
Qiyan Zhou
zhouqy1994 is on a distinguished road
U cellPointFace;
rho cell;
p cell;
T cell;
to
U cell;
rho cell;
p cell;
T cell;
Hope it works
mehdi
hi mehdi
it really works
by the way, do you know the reason why it doesn't work for cellpointface?
however, both cell and cellpointface work well in parallel in foam-extend 3.2, when only cell suport the parallel running in foam-extend 4.0, can you give me
a hint why this happens?
moverover, when i use cell, the caculation always crashes for temperatue lower than 200k at the beginning of injection, i use dieselEngineFoam
thanks
zhouqy1994 is offline   Reply With Quote
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Segmentation fault with parallel computing Prad Main CFD Forum 0 December 11, 2008 08:44
Segmentation Fault when using class based on KinematicParcel in parallel gschaider OpenFOAM Bugs 1 August 18, 2008 07:18
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Fluent parallel: segmentation fault? hp FLUENT 2 September 6, 2001 15:18
