April 29, 2010, 03:51 |
#21 |
Mattijs Janssens
Rep Power: 26 |
There is no concept of internal boundaries. Instead create a cyclic baffle. This will not affect the flow but allow you to do 'patch things'.
Use createBaffles to convert a set of internal faces into baffles on an (existing) cyclic patch. |
April 30, 2010, 06:15 |
#22 |
Jiang
Rep Power: 16 |
Dear mattijs,
Thanks for you answer. But I am confused. I just want to create this plane, and sampling data in this plane. First I generate fluent mesh, and set this internal plane using "interior" boundary. when converted to Foam mesh, this plane becomes a faceZone called "int_SAMPLING". I use [ createBaffles int_SAMPLING samplingplane ] , then this internal plane becomes two sided wall. Then what should I do to create cyclic baffle ? Thanks . |
June 14, 2010, 03:31 |
#23 |
Adrian Stalder
Rep Power: 16 |
Hi everyone
Thanks for posting this guide of how to sample an internal plane. It was of great help so far. However I got an additional question for that. I already ran tons of simulations and I would like to have these internal faces values. It works ok with mapFields for the general fields, but not for phi for example. Do you have an idea how I can get other than the standard fields onto this "new" mesh with internal faces? Cheers Adrian |
