Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Minor compilation problem with Gcc42
Old   May 9, 2007, 13:39
Default OpenFOAM-1.4 on 32 bit Intel
David P. Schmidt
schmidt_d is on a distinguished road
Not sure if this really counts as a bug, but it might be worth fixing anyway.
If you set "$WM_COMPILER" = "Gcc42" (and I am using gcc4.2) and this is a 32 bit build, then wmake doesn't have a corresponding rules directory in the
OpenFOAM/OpenFOAM-1.4/wmake/rules
It looks like you can just copy the rules from linuxGcc4 to linuxGcc42.
Are there special rules for GCC4.2 that are not backwardly compatible with GCC4.0 ? Just curious.
schmidt_d is offline   Reply With Quote
Old   May 9, 2007, 14:11
Default Yes what you have done is corr
henry is on a distinguished road
Yes what you have done is correct. The reason we are not officially supporting gcc-4.2.0 is that it hasn't officially been released. I am now compiling and running with gcc version 4.2.0 20070317 (prerelease) and have not encountered any problems and the next version of OpenFOAM will be released compiled with gcc-4.2.?, whichever is the latest stable version at the time of release.
Henry
henry is offline   Reply With Quote
!!! UDF - Compilation problem !!! Everest FLUENT 1 January 12, 2009 18:56
Minor buoyancy problem in Phoen2007 patti Phoenics 3 December 1, 2007 19:43
Minor wmake problem for x86_64 when compiling everything using existing gcc WM_COMPILER%3dbb hoogland OpenFOAM Installation 0 August 13, 2007 09:58
udf compilation problem co2 FLUENT 4 April 16, 2004 18:34
Gambit Meshing export to fluent minor problem John c. FLUENT 2 February 6, 2002 17:52
