Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Cumulative patch for OpenFOAM 14
Old   June 15, 2007, 08:01
Default To recompile PVFoamReader I do
  #21
Ruben I. Mukhamadeev
benru is on a distinguished road
To recompile PVFoamReader I downloaded & install cmake (I see it in Allwmake in correspond directory), but make process was stopped with :
+ cd PVFoamReader
+ mkdir -p Make/linuxGcc4DPOpt
+ cd Make/linuxGcc4DPOpt
+ cmake ../..
-- Check for working C compiler: OpenFOAM/linux/gcc-4.1.2/bin/gcc
-- Check for working C compiler: OpenFOAM/linux/gcc-4.1.2/bin/gcc -- broken
CMake Error: The C compiler "OpenFOAM/linux/gcc-4.1.2/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
OpenFOAM/OpenFOAM-1.4/wmake/gmake: cannot make, Make directory does not exist
CMake will not be able to correctly generate this project.
-- Configuring done
+ make
make: *** Do not find sources and makefile.
stop.
Could you advise me what to do to build PVFoamReader ?
benru is offline   Reply With Quote
Old   June 15, 2007, 11:16
Default I have already given a workaro
  #22
Alberto Passalacqua
I have already given a workaround in the 4th comment to this tread.
Just skip it and use the binary version provided with OF 1.4.
Then manually recompile the remaining directories (preProcessing, surface, thermoPhysical) by entering into them and using wmake all.
Regards,
A.
Alberto Passalacqua
Old   June 15, 2007, 12:14
Default Is this cumulative patch alrea
  #23
Rui Alexandre Trigo Ribeiro Pereira
ed_teller is on a distinguished road
Is this cumulative patch already installed in the OpenCFD release of OF 1.4? is it Just for the initial release, or does it still apply for the most recently downloaded versions...?
ed_teller is offline   Reply With Quote
Old   June 15, 2007, 12:38
Default To my knowledge, it's not incl
  #24
Alberto Passalacqua
To my knowledge, it's not included in the download version.
I just put the corrected files provided by Henry together to group them in a simple package.
Regards,
A.
Alberto Passalacqua
Old   June 18, 2007, 03:29
Default I use OF 1.4. Command Engin
  #25
nishio
I use OF 1.4.
Command EngineCompRatio have bugs?
I got this error message.but i did't got error in
OF 1.3.
What files have bugs?
Please teach me.
nishio@linux:~/OpenFOAM/nishio-1.4/run/tutorials/dieselEngineFoam> engineCompRat
io . cyclic_test
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : engineCompRatio . cyclic_test
Date : Nov 13 2007
Time : 15:15:45
Host : linux
PID : 13610
Root : /home/nishio/OpenFOAM/nishio-1.4/run/tutorials/dieselEngineFoam
Case : cyclic_test
Nprocs : 1
Create engine time
Create mesh
Selecting engineMesh layered
deckHeight: 0.16539
piston position: 0.01339
CA = 0
deltaZ = 0.095
clearance: 0.057
Piston speed = 3.8 m/s
CA = 0
deltaZ = 0
#0 Foam::error::printStack
#1 Foam::sigFpe::sigFpeHandler
#2 Uninterpreted: [0xb7f5f420]
#3 Foam::fvMesh::movePoints
#4 Foam::layeredEngineMesh::move
#5 main
#6 __libc_start_main
#7 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i38 6/elf/start.S:122
Floating point exception
Old   June 18, 2007, 05:59
Default 2 Alberto In accordance wit
  #26
2 Alberto
In accordance with your advice I recompiled /src and applications/(preProcessing, thermophysical & surface), all is ok, many big thanks.
regards
Ruben
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 10:42
Patch for openfoam ztdep OpenFOAM Installation 1 April 27, 2008 02:29
Cumulative patch for OpenFOAM 141 January 3rd 2007 msrinath80 OpenFOAM Bugs 6 January 4, 2008 11:12
Cumulative patch for OpenFOAM 141 October 25th 2007 jfb OpenFOAM Bugs 5 October 30, 2007 17:29
cumulative particles number density ahmed Main CFD Forum 0 June 12, 2006 07:47
