Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
ChannelOodles in parallel
Old   August 17, 2007, 06:42
Default if no of cells in the directio
Maka Mohu
maka is on a distinguished road
if no of cells in the direction that we decompose over is not dividable by no of processors. decompose Par works OK but we get the following error when running.
To reproduce the error:
tut; cd channelOodles/channel395
rm -r 0;
cp -r 0.org 0;
modify blockMeshDict to have 63 cell in x direction.
decomposePar with :
method simple;
simpleCoeffs
n (2 1 1);
delta 0.000001;
nohup mpirun -np 2 channelOodles .. channel395.50 -parallel;
To remove the error:
make no of cell 64 in x dir.
DECOMPOSEPAR OUTPUT:
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.27 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
Processor 0
Number of cells = 47250
Number of faces shared with processor 1 = 3118
Number of boundary faces = 4996
Processor 1
Number of faces shared with processor 0 = 3118
Processor 0: field transfer
Processor 1: field transfer
End.
ERROR MESSAGE:
Create time
Create mesh for time = 0
[0]
[0]
[0] --> FOAM FATAL ERROR : Cannot find patch edge with vertices (11 1630) on patch procBoundary0to1
Can only find edges
4
(11 86)
(8 11)
(11 14)
(10 11)
connected to first vertex
[0]
[0] From function processorPolyPatch::updateMesh()
[0] in file meshes/polyMesh/polyPatches/derivedPolyPatches/processorPolyPatch/processorPolyP atch.C at line 351.
[0]
FOAM parallel run aborting
[0]
[1]
[1]
[1] --> FOAM FATAL ERROR : Cannot find patch edge with vertices (1608 9) on patch procBoundary1to0
Can only find edges
4
(1608 1555)
(1605 1608)
(1608 1611)
(1609 1608)
[1]
[1] From function processorPolyPatch::updateMesh()
[1] in file meshes/polyMesh/polyPatches/derivedPolyPatches/processorPolyPatch/processorPolyP atch.C at line 351.
[0] Foam::error::printStack(Foam:stream&)
[0] Foam::error::abort()
[0] Foam::processorPolyPatch::updateMesh()
[0] Foam::polyBoundaryMesh::updateMesh()
[0] Foam::polyMesh::polyMesh(Foam::IOobject const&)
[0] Foam::fvMesh::fvMesh(Foam::IOobject const&)
[0] Foam::regIOobject::write(Foam::IOstream::streamFor mat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const
[0] __libc_start_main
[0] __gxx_personality_v0
[1]
[1]
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 7241 failed on node n0 (127.0.0.1) with exit status 1.
maka is offline   Reply With Quote
Old   August 20, 2007, 14:23
Default I followed your steps but cann
Mattijs Janssens
mattijs is on a distinguished road
I followed your steps but cannot repeat your problem. You are running 1.4.1 I hope?
mattijs is offline   Reply With Quote
Old   August 21, 2007, 05:04
Default no. I'm using V1.3. Was there
Maka Mohu
no. I'm using V1.3. Was there a problem in that version? I do not know if it is too much to ask you what are the files that had the probelm (decompostPar only or others). Sorry, to move to 1.4.1 I need to do lots of testing. I will do it as soon as I can. Thanks Mattijs.
Best regards,
Maka.
Old   August 21, 2007, 18:30
Default By heart: check processorPolyP
Mattijs Janssens
By heart: check processorPolyPatch.C and coupledPolyPatch.C for differences between the two.
ChannelOodles maka OpenFOAM Bugs 12 February 5, 2009 19:17
[Gmsh] ChannelOodles with gmsh lofty OpenFOAM Meshing & Mesh Conversion 7 April 16, 2008 17:44
Parallel postChannel from within channelOodles for DNS and LES maka OpenFOAM Running, Solving & CFD 1 February 18, 2008 14:08
GradP in channeloodles nikos_fb16 OpenFOAM Running, Solving & CFD 0 September 11, 2007 05:28
GradP in channeloodles nikos_fb16 OpenFOAM Running, Solving & CFD 0 September 10, 2007 10:46
